Old 03-11-2020, 03:55 PM   #1
sick472
sick472's Avatar
Non-Stock Tow Hooks Front and Rear Options?
I want tow hooks for the front and rear of my 72 just for that freak occassion when it needs to be put on a tilt bed. Worry insurance I guess.
I have read alot of threads here about the rare 72 hooks and the even more rare rear hook adders, but I'm not into paying for rare...I just want functional that won't cause damaged bumpers from chains/cables.
Anybody have that lead?
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 03-11-2020, 06:20 PM   #2
71gmcC15
71gmcC15's Avatar
Re: Non-Stock Tow Hooks Front and Rear Options?
Hers a thread I made about installing 88-98 pickups tow hooks. The chain may scratch your bumper on extreme cirumstances but that not a worried for a daily like mine. Probably don't what that on a show queen.
http://67-72chevytrucks.com/vboard/s...d.php?t=791145
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 03-12-2020, 07:48 AM   #3
We used to fabricate our bumpers when I was into 4 wheeling. We would weld chain hooks up. That way all you need is chain. A broken chain with no hook can still be used.
We always called these Jeep hooks, the accessory hooks made for 4wds. Back when people ran brush guards these hooks would be attached at the bottom of the side plates. The first set of factory tow hooks I bought were new take off. They came from a K/5 original owner who removed the factory tow hooks to mount a brush guard. TSC sells the Jeep hooks. Clips are offered for mounting under the frame. These hooks are inexpensive and they work
Old 03-12-2020, 07:55 AM   #4
sick472
sick472's Avatar
Thanks for the link 71! I am holding that as a possibility, but would like to find something that hangs a bit lower to avoid scratching "the queen". I do plan on driving this truck regularly - rain or shine. I am looking forward to my fist new truck and hope to keep it looking good for as long as possible.
I have an 85 K20 and the front hooks look like they hang down quite a bit, but I have not had the time to check the measurements to see oif they will work on the 72. I did look at the rear frame and it sure is tucked up high above the rear bumper...not sure what needs to be done their to mount a hook of some sort....maybe a tow bar, even though I would like to avoid that.
1972 C10
1985 K20
Old 03-12-2020, 08:13 AM   #5
sick472
sick472's Avatar
Special, I think I have seen these at the local farm stores. Are you saying that there is an option that mounts directly to the frame or additional bracketry would be needed. I have the stock repop chrome bumpers front and back and need to get the hooks down below them.
1972 C10
1985 K20
Old 03-12-2020, 09:51 AM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I have hooks like the ones Tim posted above. Very affordable and very tough. Single rear hook is bolted to the bottom of the step bumper. The front hooks are bolted to the bottom of the frame rails. I used a small spacer, about 3/16" thick, so the hooks will clear the front bumper. Truck is still in paint prison so no pics, sorry.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 03-12-2020, 01:46 PM   #7
71gmcC15
71gmcC15's Avatar
Instead of using a chain that will scratch your bumper use a tow strap. They shouldn't hurt your bumper.
Old 03-12-2020, 09:58 PM   #8
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
I have used 73-80 hooks before. They are flat with good girth. The 81-91 square body version are different.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 03-13-2020, 07:30 AM   #9
Mike C
Mike C's Avatar
I have the ones like Tim posted on the front of my Jimmy. Had a set on my old C2500 ‘70 as well. And they are handy dandy if you need to pull from the front.
Anymore I can weld and fab and am a front receiver guy. Gives you more options. On my kids ‘72 Jimmy we used the same off-road hooks but I mounted a bolt on receiver that sandwiches between the hook and the frame that gives you both options.
Receivers make great tow points for straps. Just put the eye of the strap in and insert the 5/8” hitch pin through the eye and pull away.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-27-2020, 11:10 PM   #10
Sheepdip
Sheepdip's Avatar
You guy's don't send me death threats.... but I installed late model F150 tow hooks, used one existing hole and drilled one. They hang down enough to get a strap or chain thru them.
I think they look nice since they are chrome and don't stick out to far, they will serve the purpose should I ever need them.
https://www.amazon.com/7BLACKSMITHS-...s%2C239&sr=8-5
Sheepdip is offline   Reply With Quote
Old 10-28-2020, 12:24 AM   #11
gmc684x4
Omg sacrilege..
They do look like they belong
Does not McMaster carr have sets on tow hooks
I do not like the 88 up tow hooks i have broken one in the past and doesnt feel like the same quality as the old hooks
gmc684x4 is offline   Reply With Quote
Old 10-28-2020, 08:38 AM   #12
sick472
sick472's Avatar
Originally Posted by Sheepdip View Post
You guy's don't send me death threats.... but I installed late model F150 tow hooks, ...
Very nice! Even if they are not true to the General. I'm not a purest and would prefer those over the China cheapies, but I have already bought some for the front from the Harbor and am happy with the results.
Thanks for joining the thread! Great option.
I have not come up with any ideas for the rear just yet. The sport bumper position with respect to the frame does not lend itself to just "bolting something on".
1972 C10
1985 K20
Old 10-28-2020, 02:23 PM   #13
72c20customcamper
72c20customcamper's Avatar
Bought these on craigslist the set on the left are later gms I believe
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 10-28-2020, 02:32 PM   #14
BRL
BRL's Avatar
Those do look nice!
I forgive you.
Bet they work just as well as those $828.13 hooks on the other thread.
ETA: I had to have my truck towed once and they bent the front bumper.
I had to replace it later anyway because I bent it even worse, so now I just ordered a set of those Ford hooks from Amazon.
Never know when I might break down on the road and need a tow.
...and I saved $800 over the originals!
BRL is offline   Reply With Quote
Old 10-28-2020, 04:00 PM   #15
Ironhorse
Ironhorse's Avatar
Don't have pics right now but I used a set of the 73-80 square body tow hooks for the rear with the " J " opening pointed to the front. Have a step bumper on rear and with just a slight amount of enlarging the bolt holes for the bumper to bracket mounts they bolted right in. Just used a bit long bolt with washers and nylon lock nuts. VERY solid and clears the step bumper for a pulling point.
Do a search for "rear tow hooks" and "let's see your custom touches" will show. Go to end of page 2 for pics of the rear tow hooks.
Sure wish I knew how to do a link, hate being tech challenged, LOL.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 10-29-2020, 06:09 AM   #16
Orange Crate
Orange Crate's Avatar
https://www.clevelandhardware.com/ca...=pdfs/2800.pdf
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 10-29-2020, 10:38 AM   #17
Sheepdip
Sheepdip's Avatar
Originally Posted by BRL View Post
Those do look nice!
I forgive you.
They look like they where meant to be and are an easy install....even come with the bolts and nuts on a backing plate that fits on the frame flange no problem.
Old 10-29-2020, 11:10 PM   #18
67swb72klb
67swb72klb's Avatar
I built a crossmember and mounted a set like C20 has pictured above but in chrome
They are made by Cleveland Hardware
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 10-29-2020, 11:43 PM   #19
BRL
BRL's Avatar
Hey that's good to know, I do like how they look on your truck and really don't care what brand of truck they were actually made for.
Hope I never have to really make use of them, but if do, at least I know I'll be towed while stylin'
Old 10-29-2020, 11:51 PM   #20
Sheepdip
Sheepdip's Avatar
You'll like them!
I know what you mean it's always nice to have a couple of
"Hook" points for chains/straps when you need a tow or a tug out of a muddy spot.
