Old 03-02-2020, 06:46 PM   #1101
ZohmBii
Re: What did you do to your truck today.The 3rd chapter
Got the Broski's truck fired up this weekend, found a few leaks and had to pull off the intake manifold to reseal the rear. At least we caught it now so it wasn't too bad.
After getting that done we set the timing and she fired up great. I gotta say I'm impressed by how easy this newer EFI stuff is making it.
I posted a video of the kid starting his truck up over on my Instagram. Here's a quick link: https://www.instagram.com/p/B9PILuPJKXw/
1969 K10 LWB - 383/SM465/T221/4.56 - 8" of lift and 40" tires - the broski's truck aka JackdTruck
1974 C30 Crew Cab Dually - No Eng/No Trans/Bagged sometime in the 1990s and will be worked on sometime in the 2020s
... And a whole gaggle of other projects.
Check out what I'm up to on Instagram: @zohmbii
ZohmBii is offline   Reply With Quote
Old 03-02-2020, 09:17 PM   #1102
mygmctruck1
I spent most of the day removing my steering arm , gotter Done but boy what
a. PITA
mygmctruck1 is offline   Reply With Quote
Old 03-03-2020, 11:32 AM   #1103
sfont66
sfont66's Avatar
Originally Posted by BugzC10 View Post
I used this wrench to reach the back bolts. It was slow and tedious, not perfect, but got it done.
Thanks, I will look for one like that. Or perhaps I could make one by heating an old cheap wrench with a torch and bending it .
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is offline   Reply With Quote
Old 03-09-2020, 07:31 PM   #1104
72c20customcamper
72c20customcamper's Avatar
Did the front half of my headliner on the 77. Really dont want to do the back it was a pain in the butt. Think if they didn't use foam it would still be up there . Foam failed not the glue
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-09-2020, 07:31 PM   #1105
72c20customcamper
Black stuff is what's left of the foam
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 03-09-2020, 07:33 PM   #1106
72c20customcamper
Close up of the snake bite pattern
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 03-09-2020, 07:37 PM   #1107
72c20customcamper
I made two of them with ratchet type head one for loosing and one for tightening. Easy to do just heat it up and bend the crap put of it
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 03-11-2020, 07:17 PM   #1108
Andy4639
Old member
Andy4639's Avatar
I got the stacks hooked up this morning and painted the bed sides this afternoon!
After & before.
https://www.youtube.com/watch?v=h-3YgxE12T0
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-11-2020, 09:54 PM   #1109
sfont66
sfont66's Avatar
Great idea! thanks, I will have to make 1 each
Old 03-11-2020, 10:56 PM   #1110
Astro-Balls
Astro-Balls's Avatar
Vent window seals, and window channels.
Also working on a couple of Ford Phaetons, 1934 and a 1935..
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 03-11-2020, 11:22 PM   #1111
72c20customcamper
Worked in a restoration shop on long island . I have polaroids of it but I believe this is the one since it's one of one 1929 Bentley made for the Paris auto show . The car had been cut up during WWII and was used as a tanker on an RAF airfield . Owner was adamant about leaving the holes in the frame from it being strafed by the luftwaffe. I did the aluminium came as a rough piece I shaped it sanded it to a mirror shine . Took 6 weeks my arms were shot. This was in 1978 .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 03-13-2020, 10:17 PM   #1112
sfont66
sfont66's Avatar
Had the day off work, so I took the opportunity to weld up the new inner rocker,kick panel and outer rocker .
Old 03-17-2020, 08:43 PM   #1113
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today.The 3rd chapter
Welded in a lockable tool box into the bed side of the ramp truck. Going to paint it to match the bed better.
Old 03-17-2020, 09:51 PM   #1114
rustytruck50
rustytruck50's Avatar
Replaced the old, leaky master cylinder cap on my '98.....hoping to give the '72 some attention soon
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 03-18-2020, 06:32 PM   #1115
tdangle
tdangle's Avatar
Got my new crate motor dyno'd today. 249/329 at the rear wheels. Not to bad for a mild cam'd 350
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 03-18-2020, 08:16 PM   #1116
67C10Step
67C10Step's Avatar
Got the drivers side step for the bed in rust remover to get it clean for priming. Hope to get both sides in epoxy primer by end of weekend. Pulled vent door from passenger side and vacuumed out at least 5 pounds of leaves and junk. Still needs more work but gonna pull drivers side as well.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 03-20-2020, 08:13 AM   #1117
Daron65
I will be going to get it from the alignment shop. Hopefully its better.
1971 Chevrolet C20, Blueprint 355. Holly Street Avenger 430HP. Turbo 350
1952 Chevrolet Deluxe. Stock. True survivor with 1 paint job
1953 Buick Special. GM 355. Just a good smooth engine.
Daron65 is offline   Reply With Quote
Old 03-22-2020, 02:04 PM   #1118
ohboy321
ohboy321's Avatar
Started routing out the cracks in my 67's new steering wheel in preparation for epoxy. It is going to look at lot worse before it looks better.
Steve/NH
1967 K10 327 Short Bed Stepside
ohboy321 is offline   Reply With Quote
Old 03-22-2020, 02:14 PM   #1119
Knight72
Stripped the door panels out. Two tiny holes. Think I may have one of the best sets of doors around. I was stoked about not needing to reskin or patch the shell extensively. Installed the 4in rear drop springs and track bar. Working on spindles today.
72 C10 lwb fleetside aka Big Rhonda.
Still plugging away.
Build thread:
http://67-72chevytrucks.com/vboard/s...42#post8247142
Knight72 is offline   Reply With Quote
Old 03-22-2020, 03:05 PM   #1120
Markus_E
I get my bedwood finished this week. It looks a little better then the old one
Markus_E is offline   Reply With Quote
Old 03-23-2020, 09:07 AM   #1121
zicc1835
zicc1835's Avatar
very nice.......
zicc1835 is offline   Reply With Quote
Old 03-23-2020, 09:00 PM   #1122
66clow
66clow's Avatar
Closer to making it cool. Just hoses left to install.
66clow is offline   Reply With Quote
Old 03-25-2020, 10:34 PM   #1123
67C10Step
67C10Step's Avatar
Repaired bad section in my intermediate wiring harness. Confirmed the tail lights and back up lights would now work (if installed). Will work on stop and turn signal next. Got tired after a day of moving furniture.
Just working on some small stuff while being socially distant. Going to try to get my bed steps fully stripped and in epoxy primer as well.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 03-29-2020, 07:34 PM   #1124
SRU1436
Finally got around to putting the sound deadener and new carpet. Next weekend will reupholster the bench and then I’m good to get her back on the road. It’s been six weeks since I’ve driven her and I’m going through withdrawals.
SRU1436 is offline   Reply With Quote
Old 03-29-2020, 07:35 PM   #1125
SRU1436
Oooppss. Sorry they are sideways
