Re: Nv3500 seals
I had a similar situation with my 5LM60, leaking from the top. Actually, the problem was my knuckles hitting the dash. The bolts that hold the shifter housing were loose, the threads in the aluminum transmission case were stripped. I finally mustered enough courage and put in a heli-coil type part. That second seal that you posted, I should have replaced that, it was chewed up. I put gasket goo on it instead.
'47 Panel to '88 K2500 Frame Swap Mechanical Speedometer Drive Solution 1947.2 1 ton Chevy Panel 1955.2 Chevy 6700 Bus/RV 1990 Chevy K1500 |
| Bookmarks |
