Old 03-13-2020, 10:54 AM   #1
03BlkZ
Track Bar question
I plan to do a 2/4 drop on my 70 short bed C10. Do I need an adjustable track bar with the 4 inch rear drop? I assume so but wanted to check for sure. Also, what is the lowest you can go before having to C Notch the frame. My new spindles in front are 2.5 drop and I am hoping a 4 rear drop will get it fairly level.
03BlkZ is offline   Reply With Quote
Old 03-13-2020, 11:01 AM   #2
67C10Step
67C10Step's Avatar
Re: Track Bar question
I've seen conflicting thoughts on the 4" drop and track bar but I went ahead and bought an adjustable unit when I did my 4" drop. Sort of figured another $100 added to the cost of reworking all the suspension and brakes wasn't really that much.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 03-13-2020, 04:02 PM   #3
Lanman1972
Lanman1972's Avatar
Shock relocate brackets too! Not sure if the adjustable panhard bar is required but I also used one for my 2/4 drop.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
Old 03-13-2020, 04:25 PM   #4
HO455
HO455's Avatar
To answer your question after you get the truck lowered measure the rear end to the frame to see how far the rear end is off set from the center of the frame. (I would not rely on measurements to the body too many ways for it to be incorrect) The adjustable track bar is used to correct this problem. If you rear end is centered still then you won't need it.
Scroll to post 511 on the link and you can read my posts on installing a track bar and centering it.
https://67-72chevytrucks.com/vboard/...698377&page=21
RIP Bob Parks.
Old 03-14-2020, 09:49 AM   #5
Zeroman
Zeroman's Avatar
Just remember to measure from the inside of the tires to the frame on each side to get your adjustments.
The "pumpkin" of the differential is offset, so measuring from the center of the yoke "does not compute".
Zeroman is offline   Reply With Quote
