03-15-2020, 10:44 PM | #26 |
Re: Torn between Carb vs Holley Sniper
Does any OEM still produce factory TBI?
03-16-2020, 02:34 PM | #27 |
For what you want, a basic crate 350 with a Tuned-Port on top will do wonders. I have done several TPI conversions over the years. My '83 K20 went from 14 mpg to 17 going from the stock 350 to a stock '91 TPI 350. Turn the key and it starts, no cranking and cranking when the Q-jet leaks. And the difference in power is something you can feel. When towing I would hit the 4 bbl going up a hill. With TPI I just add a little pedal and it pulls on. Parts are available at any parts store in the country because it's factory GM. The TPI units can be had for like $200 or less now. Yes on the initial side it will cost more for injectors and a pump and wiring-but they run and run. Worth thinking about IMHO.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
03-16-2020, 02:53 PM | #28 |
I found this a while ago when thinking about the same thing,
https://howellefi.com/product-catego...lete-tbi-kits/
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
