Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-18-2020, 06:11 PM   #11
harrisoncole4
harrisoncole4's Avatar
Re: 1969 Blazer - 507 Light Blue
Originally Posted by DeadheadNM View Post
Looks like you’re off to a great start. I’m definitely on board. Color choice is great. 69 model Blazers are fun - good luck with the build.
Have you seen the Pacific Fab/Tilden 4wd X-member? Only mentioning because it looks closer to an oem piece and sleeker than the DD.
I have seen the Pacific Fab xmember. The reason i had thought the DD unit was the way to go was that most reviews seemed to say the DD will clear the front axle with less of a lift than the PacFab unit. I like the look of the 33's on stock height springs. I have not looked into it enough to see if either xmember can support that.
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858
harrisoncole4 is offline   Reply With Quote
