Old 03-20-2020, 02:27 PM   #1
Hart_Rod
Hart_Rod's Avatar
Re: Big 10 adventure!
Originally Posted by MikeB View Post
For sure! One of the toughest projects I've done on my 82 C10. I recall using lots of silicon spray and and a plastic putty knife to "persuade" the rubber into place.
FYI, if your truck doesn't already have them, these "upper door seals" will help seal out wind noise and water. From what I understand, they were used only on high end models and snapped in. These aftermarket versions have a strong adhesive on one side. They made a big difference on my truck, and got rid of some wind noise and a pesky water leak. A great addition to new door gaskets.
https://www.soffseal.com/ss-9352
Do you have a picture of these installed? Thanks!
Hart_Rod is offline   Reply With Quote
Old 03-20-2020, 04:06 PM   #2
MikeB
MikeB's Avatar
Here you go. It essentially gives you a double seal at the top half of the door. It seals against the cab outboard of the main door seal. On mine, there are some places where the main seal just barely touches the door, so this seal will help keep wind and rain from ever reaching the main seal.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 03-20-2020, 06:28 PM   #3
Hart_Rod
Hart_Rod's Avatar
Thank You! Does it affect the way the door closes?
Old 03-20-2020, 06:58 PM   #4
MikeB
MikeB's Avatar
Minimal, if anything, on my truck. Not like new perimeter door seals, which usually make the door a little harder to close for a while.
It's one of the best bangs-for-the-buck addition or mod I've made on the truck. Along with sound deadening and heat insulation on the cab floor, the truck is very quiet inside. Wind noise, road noise, and exhaust noise are all subdued compared to what I started with. May have to get some louder mufflers!
Mike
Old 03-20-2020, 07:30 PM   #5
VWNate1
VWNate1's Avatar
Thumbs up Quietude
? Who needs mufflers ?! .
I realize it depends on your engine but most stock engines only need twice pipes with a proper crossover as close to the headers as possible and then a 2-1/2" pipe all the way to the back to sound very nice and not overly loud .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
