Old 03-21-2020, 04:19 PM   #6
akart
Re: Q-jet to square bore
Originally Posted by MikeB View Post
Jon Hardgrove at The Carburetor Shop probably knows more about carbs than anyone in the business. From an article quoting him:
"Jon warns that if you are changing from a square-bore carburetor to a spread-bore model, it's important to use the appropriate manifold. "Never use an adapter," he advises. "For maximum efficiency and performance, you want a manifold that's correct for the type of carburetor you're using."
And I like this comment:
For street-driven cars, Jon suggests spread-bore carburetors like the Rochester Quadrajet and Carter Thermoquad as "the way to fly." He says that some Holley four-barrels fall into this category, but he is not a big fan of Holleys. "Unless you have a racing application, spread bores work best," Hardgrove believes. "Assuming that you don't drive wide-open all the time, you're going to be running mostly on primaries and the spread-bore carb has smaller primaries."
Thank you very much for your input and advice. "I Believe" and I will get a new correct spread bore manifold for my Quadrajet carb.
akart is offline   Reply With Quote
