Old 03-21-2020, 02:00 PM   #251
chewychevy67
Re: My 1970 GMC Project
Cornerstone, just curious what you did here in the red circle? I know there are supposed to be 2 holes for the steering column clamp. I only see 1. Just curious how you plan for this area to clamp the column and look smooth?
chewychevy67 is offline   Reply With Quote
Old 03-21-2020, 07:43 PM   #252
Kronald_70GMC
Kronald_70GMC's Avatar
And here we have it folks. One symmetrical section from side to side. Well other than the lower piece that I still have to do. Then after that, only 10 or so more holes to fill in.
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 03-21-2020, 08:18 PM   #253
TA_C10
TA_C10's Avatar
Looks great!
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 03-21-2020, 08:33 PM   #254
Kronald_70GMC
Originally Posted by TA_C10 View Post
Looks great!
Thanks. Hoping to be back out later tonight working on the lower area.
Kyle
IG: kyle_ronald
Old 03-21-2020, 09:58 PM   #255
cornerstone
cornerstone's Avatar
Inside that red circle is just another example why we are better as a group. Moments after I read your comment there was a drill bit inside that red circle, removing a mistake! Nice catch chewychevy67! Might anyone know what tap size I now need to run through the threads previously filled with bondo?
I'm sure glad I didn't weld it up!
Sorry for the hijack Kyle...
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 03-21-2020, 10:01 PM   #256
cornerstone
Looks great Kyle! I'm scratchin' my head trying to figure out how that was done... Care to share anymore pictures?
Brian
Old 03-21-2020, 10:47 PM   #257
Kronald_70GMC
Haha I dont have many of the process but I can post another that might help. I was too caught up in the work and forgot to take pictures. Basically I just cut out the area to be raised, pounded it flat on my anvil, marked the edge at 1/4" then I just put it into my bench vise and tipped it over to match the existing. From there is was just a matter of tack..........tack............tack........ect and then grindddddddddddddd.
Kyle
IG: kyle_ronald
Old 03-21-2020, 11:31 PM   #258
cornerstone
Ahhhh!! Now its clear. Thanks.
Brian
Old 03-21-2020, 11:38 PM   #259
Getter-Done
Getter-Done's Avatar
I've got the center of the firewall all buttoned up now except for the accelerator pedal mounting nuts. I need to come up with a plan for getting rid of those but I figure I better get the pedal first. Being that this is a 72 cab and my truck is a 70, the pedal is diffrent but luckily enough my dad thinks he's got a pedal for me. Just have to go over there and see if we can find it lol.
Looking good.
About your Accelerator mounting nuts.
For Rigidity purposes,
I would suggest ,
Put a piece of cardboard over them to make a template.
Mark the location of the holes.
You could even use the pedal mounting pad.
Make a triangle plate to your Specifications.
1/2" to 3/4" thick (Bolts in plate /holes in plate )
Then you can weld that plate inside the floor.
Grind your weld nuts off once your sure of your located.
Just a suggestion
Great work I like the symmetry of the Fire-wall
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 03-22-2020, 10:01 AM   #260
Kronald_70GMC
Originally Posted by Getter-Done View Post
Looking good.
I would suggest ,
Just a suggestion
That's a great idea! Thanks.
Kyle
IG: kyle_ronald
Old 03-22-2020, 04:28 PM   #261
Kronald_70GMC
Now that I'm done with all my firewall work except for the park brake mount and accelerator mount, I figure I better show what the whole thing looks like. So I've moved some things around in my super messy garage (which I will clean when it warms up a bit more) and got the cab turned so I had enough room to take a proper picture. I really like how its turned out. Little bit of filler down the road and it will be better than new.
Kyle
IG: kyle_ronald
Old 03-22-2020, 08:11 PM   #262
chewychevy67
That looks nice
Old 03-22-2020, 08:16 PM   #263
Kronald_70GMC
That looks nice
Thanks! I like it, worth the month it took me.
Kyle
IG: kyle_ronald
Old 03-23-2020, 11:55 PM   #264
Kronald_70GMC
One more piece of the puzzle wrapped up tonight. Although we never found the complete accelerator pedal at my dad's, we did find the mounting base which is all I needed for the time being. I took a piece of 1/4" flat steel I had and cut it down to be just slightly smaller than the pedal base itself. Then I drilled the three holes for the mounting studs. After I had that figured out, I drilled about 3/4 of the depth of the plate with progressively larger drill bits so that I had a place for the weld to sit. Then I cut off the heads from some bolts for the studs which I tac welded into the holes. I did not fully weld at this point because i did not want the heat from my welds to pull the studs out of alignment. So I put the studs into the original captive nuts in the firewall and then welded it home. From there it was just some grinding to remove the captive nuts and spot welding the plate into position using the original holes! Sorry for the long winded explanation but I forgot to take enough pictures to show how I actually did it. Here are the few I did take.
Kyle
IG: kyle_ronald
Old 03-24-2020, 12:08 AM   #265
TA_C10
TA_C10's Avatar
Nice work I like that a lot better than stock. So I assume your going back with stock pedal and a cable TB?
"It's only money".
Old 03-24-2020, 01:04 AM   #266
Kronald_70GMC
Yes I am going to stick with the stock pedal setup as I am still going to be carbureted at least until I can afford an efi setup but I'm still going to be old style with a 396.
Kyle
IG: kyle_ronald
Old 03-25-2020, 11:37 PM   #267
Kronald_70GMC
I think that about wraps up the sheet metal work on the outside of the firewall. Tonight I got the E-Brake all figured out. What i ended up doing was I cut the studs out of the E-Brake so that i could reverse them and have everything except obviously the cable on the inside. Then I used an idea that I read about somewhere on this forum but I cant remember where. Thanks to whomever had posted it, I cut the two mounting holes so that they would be slotted, this allowed me to still be able to install the thing. After that, I made up another plate out of some thicker gauge metal than the firewall. I did not trust just welding the studs directly to the firewall. It probably would have been fine but I didn't want to take any chances. So after I had the plate all made up, it was just a matter of plug welding it into position.
Kyle
IG: kyle_ronald
Old 03-26-2020, 01:02 AM   #268
cornerstone
It is amazing what a guy will go through to have a clean firewall! More nice work man. You better watch out or your gonna have a trailer queen on your hands.
What kind of hooch is this???
Brian
Old 03-26-2020, 09:04 AM   #269
Kronald_70GMC
Haha thanks. That is a great western beer called original 16. Good stuff
Kyle
IG: kyle_ronald
Old 03-26-2020, 11:37 PM   #270
TA_C10
TA_C10's Avatar
It's wet, what do you care
"It's only money".
Old 03-28-2020, 10:26 PM   #271
Kronald_70GMC
Now that my firewall is done for the time being, I have been working at getting my cowl panel back on. Alot of the spot welds I drilled out went a little deep so I had to weld them up. I also got the paint stripped off the inner cowl so that I can re paint before installing the cowl. Now I have to figure out what I'm going to do with the pull vents in the kick panels. I think I'm going to delete them as I will not need them with the vintage air. My only concern is that I have heard of other guys having issues with getting fresh air. I was thinking about having some sort of opening in the delete plates I plan to make just so a little bit of air can flow through.
Kyle
IG: kyle_ronald
Old 03-28-2020, 10:31 PM   #272
Kronald_70GMC
I also have been working on welding up the seams in the corners of the windshield opening. It's crazy how diffrent these are from one side to the other. The lower drivers side and upper passenger side took far more work to get them right than the other two. I guess that's what you get when all the work is done by people instead of robots. I forgot to take a picture of the other top side but you get the idea.
Kyle
IG: kyle_ronald
Old 03-29-2020, 09:53 AM   #273
cornerstone
Now that's not only a sexy upgrade, but a smart one too! I'll bet you've totally improved your chances in having a leak free cab.
What king of tool are you using to clean up your welds?
Love the way you store your wrenches... gotta steal that one too.
Brian
Old 03-29-2020, 10:17 AM   #274
TA_C10
TA_C10's Avatar
I'm keeping my kick panel vents for that same reason. I don't want to have issues, and sometimes it's beneficial to have fresh air come in.
Windshield looks great. I should have done that one too since it's going to be my DD and I'm a little worried about windshield leaks.
"It's only money".
Old 03-29-2020, 11:33 AM   #275
Kronald_70GMC
Well thanks for the compliments. I have a small arsenal of tools to clean up my welds. My main one is a 90° air grinder with a Roloc disc attachment. I use 50 grit 3" discs. Then I also have a straight air grinder with a 3" grinding wheel for when I'm working in a concave curve. And for those super tricky areas, I have a die grinder with a 1/2" round file head (not sure what it's actually called) I can get some pictures if you would like.
Kyle
IG: kyle_ronald
