Old 03-20-2020, 04:06 PM   #1
7D2N
7D2N's Avatar
Fuel line to Edelbrock carb ?
Does anyone know if a pre-bent fuel line is available for 350 sbc fuel pump to Edelbrock carburetor?
7D2N
Just for the fun of it
7D2N is offline   Reply With Quote
Old 03-20-2020, 04:09 PM   #2
68 P.O.S.
Re: Fuel line to Edelbrock carb ?
Have you looked at the Edelbrock 8123?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 03-20-2020, 04:29 PM   #3
rockyrivermark
Not Pre bent but I used the edelbroch banjo fitting with AN fittingns and stainless hose along with an inline filter and gauge.
Wasn’t expensive.
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 03-20-2020, 04:37 PM   #4
hayhauler71
hayhauler71's Avatar
stainless hose and AN fittings
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 03-20-2020, 05:13 PM   #5
Mike C
Mike C's Avatar
The Right Stuff offers a pre-bent Edelbrock fuel line and you can get it through Summit. The reviews are not great... I would call Right Stuff and see what they can whip up for you. I found they shipped me the wrong part more often than the right, but their customer service was excellent making it right each time. They were good to work with all in all.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-20-2020, 05:52 PM   #6
sfont66
sfont66's Avatar
Like HayHauler71, I used braided steel line from pump to filter, the filter then attaches to a chrome tube with a 90 degree bend, and a banjo bolt at the carb.
The Edelbrock parts are available from summit. Part number Edl-8134 is chrome fuel line with filter. Edl-8123 is fuel line, I believe it came with fittings, you would have to cut fuel line to desired length. I also needed a fitting to adapt to my mechanical fuel pump . That part number was Ear-949096Erl. The blue earl fitting didn’t match the edelbrock fitting, as far as color though. I added a pic that showed how the chrome tube runs under carb then up in back to carb fitting.
I did later modify the line from the pump to add a fuel pressure regulator.
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is offline   Reply With Quote
Old 03-21-2020, 08:08 PM   #7
7D2N
7D2N's Avatar
Thanks guys, my plan is to stay close to stock if I can. Nice looking engine bays.
7D2N
Old 03-21-2020, 10:45 PM   #8
68 P.O.S.
Edelbrock also has the 81233, which is black.
Old 03-21-2020, 11:56 PM   #9
chevykevy
chevykevy's Avatar
I have bent my own using 3/8 steel on a number of my trucks to try to keep a semi-stock look using a small piece of rubber in between the steel from the fuel pump and the hard line you can buy on eBay or summit etc. with a filter
My profile Pic has one as well
chevykevy is offline   Reply With Quote
