Old 01-15-2020, 07:27 AM   #701
chewychevy67
Re: 67 GMC super custom build
I'm just worried if I double it up and tighten it down it will bind or put too much pressure on the oil pump.
chewychevy67 is offline   Reply With Quote
Old 01-15-2020, 11:15 AM   #702
67 Burb
67 Burb's Avatar
Right. Best to find out what the problem is and fix it properly.
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 01-18-2020, 12:41 PM   #703
chewychevy67
Got it fixed. Just lightly tapped the oil pump shaft down and it dropped a little. Now the distributor sits nicely. Next to get the driveline on the frame
Old 01-18-2020, 12:54 PM   #704
Getter-Done
Getter-Done's Avatar
Is the T400 and gear vendor unit the plan for the drivetrain?
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 01-18-2020, 02:36 PM   #705
chewychevy67
Yes it is
Old 02-20-2020, 01:30 PM   #706
chewychevy67
Getting it off the stand today! Should be on the chassis next week. Took a break from anything major for a bit but feeling like getting back at it again.
Old 02-20-2020, 10:38 PM   #707
Kronald_70GMC
Kronald_70GMC's Avatar
Looking good. When do you plan to have it running?
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 02-21-2020, 10:50 AM   #708
chewychevy67
It was supposed to be running before Xmas. Guess I missed that ship. I'll probably get it all in the chassis Tuesday. From there It will probably be a month. Need to get my rad done still before I can run it.
Old 03-22-2020, 09:50 PM   #709
67ChevyPickupMan
67ChevyPickupMan's Avatar
The suspense of seeing your truck done is killing me and my dad. Your doing some amazing work though. Want to work on my truck. LOL! Have a good day.
67ChevyPickupMan is offline   Reply With Quote
Old 03-23-2020, 12:31 AM   #710
chewychevy67
Thanks for the kind words. I too wish it could happen faster. Happy to have you following along.
Old 03-24-2020, 11:07 AM   #711
67ChevyPickupMan
Not to fast though, you do want to enjoy the moment of things coming together piece by piece. Happy to have you on here too, giving me ideas for truck
Old 03-28-2020, 08:47 PM   #712
chewychevy67
My next modification. Ez lift tailgate and tailgate lowering damper from the newer Silverados. When completed you will never even know a mod was done with the gate on the truck. Plus I'm going to use the trunions with the delrin bushings to quiet down the gate when in use.
Old 03-28-2020, 10:12 PM   #713
Kronald_70GMC
That is awesome! I was just wondering if that would be possible the other day. Where did you get all the parts?
Kyle
IG: kyle_ronald
Old 03-29-2020, 12:40 AM   #714
chewychevy67
If you look at member crossbreed's build in the blazer area at the end of it he gives all the part numbers and shows how it all works. It's sweet.
Old 03-29-2020, 01:47 AM   #715
Kronald_70GMC
I'll have to check it out for sure. Thanks
Kyle
IG: kyle_ronald
Old 03-29-2020, 03:18 AM   #716
Scurry67
Agreed. That sounds like a good read. I'll have to check it out.
Project looks great!
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 03-29-2020, 09:36 AM   #717
cornerstone
cornerstone's Avatar
Thanks for bringing the crossbreed build to our attention! I'll be wanting this mod too....
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 03-29-2020, 11:53 PM   #718
kehstr
kehstr's Avatar
Do you have a link for the thread on this mod??
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 03-30-2020, 12:09 AM   #719
chewychevy67
https://67-72chevytrucks.com/vboard/...=736217&page=5. Pages 4 and 5. He has a video showing it in action. It is pretty cool
Old 04-06-2020, 01:42 PM   #720
chewychevy67
Primed my engine yesterday getting it ready to install. While priming it I noticed my new oil pump sure is noisy. I may have to replace it. Not sure if this is normal or not. Had no problem with getting oil to the rocker arms though. Pressure seems good.
Watch "Distributor noise 327" on YouTube
https://youtu.be/yxYskCEgSHA
Old 04-06-2020, 08:56 PM   #721
Corts60
Just here to tinker
Corts60's Avatar
I just read through this whole thread. Absolutely amazing work! Boy I wish had anywhere near the patience you have....
Those valve covers are amazing. As is everything else you've done.
Great work!
Old 04-07-2020, 12:27 AM   #722
chewychevy67
Thanks. I appreciate it. My engine builder said I should be ok with that oil pump so I can soon get it in the frame. With covid19 out it may take a bit as I can't have anyone over to help so I may find a few other projects to do before the drivetrain gets in.
Old 04-08-2020, 06:18 PM   #723
Corts60
Just here to tinker
Corts60's Avatar
Originally Posted by Getter-Done View Post
Is the T400 and gear vendor unit the plan for the drivetrain?.
So far out of all my truck engine/trans/gear combos, my favorite by far was the T400/Gear venders/3:73 in my 78 SWB. Loved it!
Old 04-08-2020, 09:07 PM   #724
chewychevy67
Yeah I'm pretty excited about the driveline. I wish I would have done 3:73 or even 4:10 but I hope the 3:55 rear will be ok. My engine builder built my engine for those specs so I'll leave it now.
Old 04-13-2020, 01:16 AM   #725
chewychevy67
Got the damper side all finished up today. Tomorrow I'll start doing the easy lift side of the gate,
