Old 03-22-2020, 05:18 PM   #1
ratman90
72 C10 w/ AC Evap drain hole plug
Hey guys I'm working on my AC vents cables in control unit and putting in a new selector box.
Underneath evaporator there's a hole-in there's a piece of metal can somebody tell me how this is supposed to fit in there? And should I seal it or is this for leakage?
1972 C10 LWB 2WD
307 4 speed
Rescued from Field July 2017
ratman90 is offline   Reply With Quote
Old 03-22-2020, 05:49 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 C10 w/ AC Evap drain hole plug
It’s like a trap door. Just muscle back up and leave as is.
Old 03-22-2020, 08:09 PM   #3
chewychevy67
I believe that it's to check the resistors above it to see if they are bad
chewychevy67 is offline   Reply With Quote
Old 03-22-2020, 08:54 PM   #4
ratman90
Ok cool.
I did kinda figure it out and forced it back in. Maybe should have filed the edges a bit to derust it.
But it's back in. Thanks guys.
Larry
1972 C10 LWB 2WD
307 4 speed
Old 03-23-2020, 12:32 AM   #5
FirstOwner69
FirstOwner69's Avatar
I always thought that trapdoor was to direct some A/C air to the floor if desired.
Jim
FirstOwner69 is offline   Reply With Quote
Old 03-23-2020, 11:22 AM   #6
ratman90
Interesting thought. May force it back out and clean it up a bit then. Make it easier to swing open.
1972 C10 LWB 2WD
307 4 speed
Old 03-23-2020, 11:54 AM   #7
chewychevy67
It's funny because my 67 unit has 2 of them on the bottom I believe. I'll check on that when I get back to my truck. Nope just 1. Must be seeing things
Old 03-23-2020, 12:32 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I imagined it was a weep hole for a possible heater core leak
