Old 03-23-2020, 06:15 PM   #1
CamTra
CamTra's Avatar
Rear seat getting restored
I'm waiting on my cover, but my restoration of my rear seat is getting closer. Got it painted and now working to get it bolted into place.
CamTra is offline   Reply With Quote
Old 03-23-2020, 07:00 PM   #2
SeventyOne
Re: Rear seat getting restored
Aren't you just going to have to unbolt it to add the foam, seat belts, and upholstery?
SeventyOne is offline   Reply With Quote
Old 03-23-2020, 07:09 PM   #3
CamTra
CamTra's Avatar
Yes, but just 4 bolts. My seat is a 2 bolt on the backside not a 4 bolt. I figured I'd get all that out the way and my new holes drilled and whatever fab work underneath out of the way.
Old 03-23-2020, 09:57 PM   #4
1rippen6
There should be a factory channel with nuts welded to it. I can get a picture of what it looks like if you like unless you still plan on making your our setup.
1rippen6 is offline   Reply With Quote
Old 03-24-2020, 03:41 AM   #5
CamTra
CamTra's Avatar
Yes I found them. However, the original bolts must have had rust issues as the nuts had a piece of the old bolt that seemed to be cut off stuck in them. So I grinded the old nuts off and will tack weld new bolts on the bottom.
Old 03-24-2020, 08:46 AM   #6
1rippen6
Ok, you may be able to buy square nuts at lowes if you want it to look more original. The back bolts are 1/2 coarse and the fronts are 7/16 fine just an fyi.
Old 03-25-2020, 01:17 AM   #7
CamTra
CamTra's Avatar
10-4 Thanks for that info. I think I will do that.
Old 04-13-2020, 08:51 AM   #8
Moreyel
Moreyel's Avatar
CamTra,
Nice interior. What are those high backs out of?
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2020 Ram 2500, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more.
Wife: 06 GMC Duramax 3500 4WD Single Wheel
Next: Rust removal on my Blazer.
Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup.
Members Met: Aldtime, DeadheadNM
Moreyel is offline   Reply With Quote
Old 04-20-2020, 11:39 PM   #9
CamTra
CamTra's Avatar
Sorry been working a bunch and just got back online. I'm not 100% sure. They were in there when I bought it, But they are very comfortable. They look like original seats as far as how the passenger tilts up and how the driver seat slides. But I'm not a pro on the year of seats for these Blazers.
