Dual Tank Wiring Questions
Hey ya'll,
I'm having some issues figuring out how to wire up my dual tank. I have an 1987 chevy with the original fuel system with upgraded pumps and selector valve. I have the wiring schematic for the original dual tank setup and I'm trying to connect my holley dominator EFI to it. Do I connect the fuel pump connection to the D terminal on the original system relay? or is there another way about hooking this up. I've attached both wiring harnesses for reference. Thanks for the help. |
![]() Join Date: Apr 2005
Re: Dual Tank Wiring Questions
I don't think you need to use that factory relay in the current configuration at all. You need to wire a relay that the pump signal from the Dominator harness triggers, that would then allow power to that "E" Wire. Clear as mud?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Your holley diagram below. The green wire out of the relay should "electrically" connect to E on the diagram above.
That clears things up.
Thanks again for the assistance! ![]() |
