![]() Join Date: Jul 2001
Detailing/Clean UP of Installed Engine?
Anyone have some tips and thoughts about detailing an installed 283 sbc? This is in my '57 two door sedan shown in the Alternate Tinkerings. Engine is running fine and with the dual four bbl carbs and being 70 years young really would rather not pull the engine and trans for the clean up. My body hasn't quite kept in tune with the 19 year old mind, LOL.
Want to degrease, clean and then paint, figuring to mask off and paint with a small 1/2'' brush or similar. Will remove the fan and shroud, pull headers as they need a bead blast and then re-paint with VHT Hi-Heat Header paint. Intake is stock '57 GM dual four intake, valve covers are M/T cast aluminum. Will paint the intake but leave the valve covers aluminum. Bought a pint of KBS "Motor Coater" engine enamel in Chevrolet Orange. Not doing a B/J show piece, just want to clean the engine and go back to the mid-60s high school street brawler look. Just need some thoughts about cleaning agents to use and best way to do so. Thanks.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
![]() Join Date: Jan 2011
Re: Detailing/Clean UP of Installed Engine?
Have had good luck with super clean for engine cleanup. I pull as many parts off the engine as I can and paint them separately. Pull the carbs and tape up the intake. Along with the rest of your plan you should be good.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Thanks for the reply. Kind of a moot point at the moment. My '57 is loaded in a covered trailer ready to take to the interior shop but not sure how soon that will happen. This CV thing has put a damper on so many things right now and
as much as I want this to happen just have to proceed a bit slower now. In addition to that pretty much thinking the car show, swap meet gatherings are now a moot point also.
Yup stuff is at a crawl thats for sure.
Jimmy
| Bookmarks |
