Old 03-24-2020, 09:30 PM   #1
easyrider
easyrider's Avatar
power brakes
I want to put power brakes on my 68 C-10 and I'm not sure about the set up. I have 4 wheel drum brakes and I don't want disc on front. Everything I've seen was drum/disc power brake master cylinder. Will the drum/disc master cylinder work on ALL drum or will I have to go with something else? What about the proportion valve; stay the same or change? And, if so, what else would I go with? Can anyone give me a source for a power brake set up for our type trucks? Thanks!
easyrider is offline   Reply With Quote
Old 03-24-2020, 10:10 PM   #2
Sheepdip
Sheepdip's Avatar
Re: power brakes
Google is your best friend
https://www.classicparts.com/1967-72...20group%20%231
Sheepdip is offline   Reply With Quote
Old 03-25-2020, 07:58 AM   #3
aerotest
Re: power brakes
I have a drum/drum power brake set up I am taking off now. I will send it to you for the cost of shipping if you want it. Original booster, new mc, combo valve, and mounting brackets.
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust)
aerotest is offline   Reply With Quote
Old 03-25-2020, 08:25 AM   #4
maverickmk
maverickmk's Avatar
Re: power brakes
You wouldn't happen to have any BBC's laying around for the same deal, would you?
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 03-25-2020, 08:30 AM   #5
aerotest
Re: power brakes
I wish.
Old 03-25-2020, 08:38 AM   #6
Jim Boy
Smile Re: power brakes
If you have an 8 cylinder you will be alright with an 11" booster but if it is a 6 cylinder it will hit the air cleaner. My experience anyway. Have a good one.
Jim Boy is offline   Reply With Quote
Old 03-25-2020, 08:47 AM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: power brakes
Buy a booster and put it on everything else will work with it. Nothing to add are take off.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-25-2020, 10:46 AM   #8
easyrider
easyrider's Avatar
Re: power brakes
I'll take it. Thank you! Just send me the information.
