Old 03-26-2020, 07:11 PM   #1
Steve Cole
How long should it take?
I am doing a LS swap and my motor has sat for 2.5 years. (I know) I changed the oil pump, water Pump, and every seal and gasket I could. I also replaced the oil pan so pretty much all the oil was removed from the engine. I attempted to build oil pressure today- I disconnected the coils and the fuel tank is bone dry. I tried cranking over the motor while watching a oil pressure gauge I connected. The needle never moved. I motored it multiple times, 5-10 seconds at a time. The needle never moved. They say to prime the oil pump when you have install it but I can't remember if I did that. So my question is, how long should it take to build oil pressure under these conditions?
Any suggestions what I should do?
Thanks!
Steve Cole is offline   Reply With Quote
Old 03-26-2020, 07:43 PM   #2
saxart
saxart's Avatar
Re: How long should it take?
It's probably not going to build oil pressure by hitting the starter at "5-10 seconds at a time". You really should pull the distributor and use an oil pump priming tool. You should be able to rent one for free or cheap at your local auto parts store.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 03-26-2020, 07:47 PM   #3
Steve Cole
Hi Saxart, it is an LS motor, so no distributor. I don't know of a good way to prime these motors if it's already full of oil.
Old 03-26-2020, 07:51 PM   #4
Thealien
Thealien's Avatar
When I did mine many years ago I removed the plugs and let it spin. It took a little while but it did build pressure.
Old 03-26-2020, 08:15 PM   #5
hjewell2
hjewell2's Avatar
https://youtu.be/539ClWWJMl8
hjewell2 is offline   Reply With Quote
Old 03-26-2020, 09:30 PM   #6
Steve Cole
Originally Posted by hjewell2 View Post
Great info, thanks!!!
Old 03-27-2020, 09:06 PM   #7
saxart
saxart's Avatar
Um... Wow... What a "senior moment" on my part. LOL. Sorry... Yeah, maybe don't take that advice. You said "LS" and for some reason I skipped right over that and started thinking of the SBC in my truck.
Let us know if you resolved the issue with the YouTube video.
Old 03-28-2020, 02:16 AM   #8
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
When you put the new oilpump on I think you have to shim the pump,like with feeler guages three places to center the pump or no oil pressure.Someone who knows more than I do can set you straight. I do know moroso sells a pump primer for the LS engines.
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
71cheyennesuperlongb is offline   Reply With Quote
Old 03-28-2020, 10:46 AM   #9
57taskforce
All about them K’s
57taskforce's Avatar
Lots of people have issues with the pickup tube o-ring not seating correctly and or getting cut when installing it into the pump especially if the pump replacement was done with the engine in the car or truck. If you pull the galley plug and fill the pump like the video above shows it should build pressure pretty quickly. If not I’d suspect an issue with the o-ring.
Tyler
Old 03-28-2020, 11:14 AM   #10
Wrenchbender Ret
Years ago I built a pressureiser out of an old fire extenquisher. I put a valve stem in the side near the top. Irun a hose from the outlet to the oil pressure outlet on the engine. I put a quart of oil in the tank & put air pressure to the valve stem watching the gauge.
Pull the trigger & pressure goes into the oil gallery. I have used this for 50 years & hundreds of engines. The oil pressure comes up as soon as the engine starts.
This also works good for checking low oil pressure problems. With the oil pan off I put pressure to the system & watch for excess flow.
George
Wrenchbender Ret is offline   Reply With Quote
Old 03-29-2020, 01:23 AM   #11
70c10resto
70c10resto's Avatar
I never could get oil pressure by just cranking over either. I ended up buying a priming tool from jegs and got instant oil pressure.
70c10resto is offline   Reply With Quote
Old 03-29-2020, 06:37 AM   #12
It might be that since this is the 67-72 truck forum your mind went to the mechanics of 67-72 trucks, which is what this forum is for. 67-72 GM Trucks have distributors. The only "moment" going on here was posting an LS question where it doesn't belong
Old 03-29-2020, 09:31 AM   #13
Bones72Super
Bones72Super's Avatar
X2 on the oil pump, pick up tube O-ring . If you get a used LS, that O-ring MUST BE REPLACED. they get hardened over time and shrink/crack and then it's like trying to drink from a straw with a hole in it.
WTB 71-72 Original paint Medium Red hood
WTB 1972 Very nice original Parchment seat belt set
Bones72Super is offline   Reply With Quote
Old 03-29-2020, 01:29 PM   #14
57taskforce
All about them K’s
I don’t feel this comment was necessary. A simple move of the post to the forum you felt necessary would have been fine. Maybe it’s just me...
Tyler
Old 04-04-2020, 10:39 AM   #15
cornerstone
cornerstone's Avatar
Nope... Not just you.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 04-05-2020, 10:37 AM   #16
Willie Makeit
Willie Makeit's Avatar
also notice the post also had nothing to offer help-wise other than insulting & berating the original poster. about part for the course.
Willie Makeit is offline   Reply With Quote
Old 04-05-2020, 10:34 PM   #17
57taskforce
All about them K’s
Yes sir, Lots of things I could say here but i remember what mom said about saying nice things.
OP, did you ever get pressure?
Tyler
Old 04-05-2020, 10:55 PM   #18
halfstep
My favorite part was reading that an LS engine question posted in the LSx swap section was "...posting an LS question where it doesn't belong"!!!??
Good suggestions already presented and even more creative solutions online. I will add that as important as priming is it isn't nearly as critical on an engine that has already been broken in and has decent run time on rings, bearings, etc.
halfstep is offline   Reply With Quote
Old 04-05-2020, 11:09 PM   #19
57taskforce
All about them K’s
I can see where your coming from, for those who didn’t see it originally it was posted in main 67-72 board. That still didn’t require the aforementioned useless response.
Tyler
Old 04-08-2020, 07:04 PM   #20
Steve Cole
Hi Guys,
Thanks for all the replies...except one. A little update- I did the oil pump priming procedure that hjewall2 posted. This works great BTW. Long story short.. still no oil pressure but the engine won't start either. I don't think I am going to build oil pressure until the engine actually starts short of some fancy priming rig. I pulled a spark plug and zero evidence of fuel smell on the plug. I put a noid light on the injector harness and they are being commanded to pulse so tomorrow I'm taking my injectors to be cleaned/flow checked. I believe they are gummed up from sitting so long. I will keep everyone posted!
Old 04-08-2020, 07:36 PM   #21
Willie Makeit
Hi Guys,
while a buddy tries to crank the engine, take a screwdriver and lightly tap the injectors one at a time with the handle-end until you can feel them open. you should feel a small "click". used this method several times on LS injectors in engines that sat for a while and the injectors almost always decide to work rather than being hit by the screwdriver.
you may want to check your fuel pressure at the fuel rail as well. should have 58 psi.
Old 04-09-2020, 09:29 AM   #22
Steve Cole
Thanks Willie, great advice! I'm guessing you check fuel pressure at the Schrader valve on the crossover tube?
Old 04-09-2020, 11:39 AM   #23
Willie Makeit
yes sir. you can pick up an inexpensive fuel pressure gauge at most big box automotive stores.
Old 04-09-2020, 11:27 PM   #24
Steve Cole
I picked up one today Willie. Decided to go ahead and have the injectors cleaned and flow checked as well.
Old 04-27-2020, 02:28 AM   #25
CarlsLQ9SS
CarlsLQ9SS's Avatar
I made a priming tool from an old small block chevy oil pump. Just put a drill on the drive shaft of the pump, dropped the pump in a bucket of oil, and ran a hose from the pump to the plug on the driver lower front of the block it worked really well. It is the plug that takes an alan wrench to take it off.
CarlsLQ9SS is offline   Reply With Quote
