Old 03-21-2020, 02:21 PM   #1
j_cst_10
j_cst_10's Avatar
454 TBI lean stumble on throttle tip in
Hey guys, I appreciate any advice.
I have a 91 2500 2wd suburban (square body) 454TBI with the 4L80E trans. It intermittently develops what I can describe as a lean condition stumble (although that may not be accurate but almost feels like a carb with an accelerator pump issue). If you hold your foot on the accelerator at this point it stumbles and bucks depending on load. It appears when the truck is up to temperature. During warm up it is fine. And sometimes it doesn't do it at all!
The truck runs pretty rough when it is initially started and burbles and pops, but then smooths out and drives pretty much completely normal. You can power past the stumble if you put more foot into it.
I have done a simple tune up and replaced the temp sensor in the cylinder head and cleaned the TBI the best I could with spray cleaner.
Anybody else run into this with any of the 454's with TBI?
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual
1972 Cheyenne Super Short Bed 557 Med Olive DK olive
1970 K5 Blazer Dark Gold
1966 Coronet 440 35k mile survivor
1991 Suburban 2500 454/4L80E 2wd
1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9"
j_cst_10 is offline   Reply With Quote
Old 03-21-2020, 07:26 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: 454 TBI lean stumble on throttle tip in
This just happened to me on my 1991 Chevy van with TBI and it was the EGR valve. Took me forever to find it. The diaphragm failed causing a vacuum leak. Since the vacuum source for the EGR is "ported" it only receives vacuum off idle meaning it stumbles on light throttle.
Take a handheld vacuum pump and put it on the EGR. If it doesn't hold a vacuum when you pump it up, it has failed. If you replace it, be sure to get that gasket surface super clean as well. This can be a source of vacuum leaks if the gasket isn't sealed right.
Hope this helps.
Old 03-21-2020, 07:37 PM   #3
kwmech
Not only that, but check the lower water plate under the carb. The egr blow hole in the intake has a tendency to crack the gasket in that area and cause a vacuum leak
Old 03-21-2020, 07:55 PM   #4
j_cst_10
j_cst_10's Avatar
This makes perfect sense and I wouldn’t have thought to go in either direction.
It runs like it has a vacuum leak. I did a basic leak check with all the usual culprits years ago, but that’s as far as I went. It’s been running like this for years now. It will be that much more rewarding when it’s fixed!
If anyone else has ideas keep them coming please!
Old 03-22-2020, 04:57 PM   #5
Bladeboy1998
I have an original gm tbi service manual if you need any info from it just direct message me and I will send some pictures to you.
Bladeboy1998 is offline   Reply With Quote
Old 03-23-2020, 06:37 AM   #6
cadillac_al
any codes?
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 03-23-2020, 08:28 AM   #7
j_cst_10
j_cst_10's Avatar
No codes, and the light is still working haha. I’ve done other diagnostic tasks that have triggered codes before.
It really doesn’t make a lot of sense beyond some sort of vacuum leak. I did a visual yesterday and didn’t come up with anything.
I’ll have to test the egr and spray some carb cleaner around to see if I can come up with something.
I’ll follow up when I can devote a few minutes to it.
Old 03-23-2020, 12:35 PM   #8
j_cst_10
j_cst_10's Avatar
Also thanks for the tbi manual offer.i may just need that if I can’t find a smoking gun.
Old 03-24-2020, 08:54 PM   #9
j_cst_10
j_cst_10's Avatar
Vacuum leak! I sprayed carb cleaner everywhere and didn’t get anything unusual. Then I pulled ever accessible vacuum fitting off.
The pcv line is a hard plastic line with 2 rubber couplers. When I pulled it and turned it upside down the one coupler had a split down it.
Runs normal so far on my initial test drive. Will test cold start tomorrow.
Old 03-27-2020, 08:44 AM   #10
Corts60
Just here to tinker
Corts60's Avatar
That's great! It's always satisfying to fix vacuum leaks!
Old 03-27-2020, 09:09 AM   #11
j_cst_10
j_cst_10's Avatar
Yes it is. From my short test drive it appears the drive ability issues are resolved. More driving will confirm this.
It still idles rough when stone cold. Something I thought would be fixed. I may try disconnecting the battery and see if it goes away for an extended time.
It seems to run better when the batt is disconnected but then would eventually return to its issues. I’m assuming it runs off of a set rich open loop parameters and then goes lean with the vacuum leak.
Old 03-27-2020, 09:52 PM   #12
hatzie
Moderator
hatzie's Avatar
The 1991 emissions and driveability manual as well as the service, unit, and wiring manuals are in the service manuals post.
There's also several GM Fuel Injection textbooks.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-28-2020, 09:22 AM   #13
j_cst_10
j_cst_10's Avatar
Hatzie- thanks for the info. I was interested to learn more about the tbi set up, I will go through the links shortly.
I did mention the model and year in the first post but probably a good idea to put it in the thread title.
