Old 03-29-2020, 12:15 AM   #1
evilokc
Re: front fender alignment?
my trucks was damaged many years before I got it and the cab right where the heater vent is has damage. that area of the hood will never sit right unless I cut it out and replace it. I probably wont. I spent a while moving everything as best I could and ended up with an acceptable gap. I have to hook my headlight back up and that side is complete.
evilokc is offline   Reply With Quote
Old 03-29-2020, 05:49 PM   #2
dsraven
haven't worked on one of the AD trucks in awhile but I'm on the same page as mr48, hood first then fenders.
Old 03-29-2020, 05:52 PM   #3
dsraven
https://raybuck.com/how-to-align-the...or-gmc-pickup/
Old 04-14-2020, 03:00 PM   #4
Driver_WT
Driver_WT's Avatar
Originally Posted by dsraven View Post
"If you are keeping the fender cross brace rods, the left should measure 27 1/4″ and the right should measure 27″, with the measurement taken from the center of the bolt head to the head of the bracket."
Are the measurements for the fender cross brace rods from the center of the front bolt head at the firewall?
Thanks.
Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes
Driver_WT is offline   Reply With Quote
