Plywood bed for working truck
I need to replace the rotted bed-wood in my short fleet box.
This truck will do some light hauling, and I don't want to install new bed-wood & strips. I was thinking about treated 3/4 plywood, and maybe a rubber bed mat. Has anyone installed plywood in their bed Any Pics ?? |
![]() Join Date: Aug 2004
Re: Plywood bed for working truck
I wouldn’t do the bed mat unless you take it out after use. They hold water under so...
Treated plywood is a good idea, you will need two 4x8 sheets. 3/4”
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
It should work. I guess you will have to put a 1" strip across the front. With tongue and groove, if you plan on using it, I can't remember if they do all 4 sides or just the long sides. I think just the long sides.
Edit: I just noticed you have short box so regular plywood is long enough. I'd still go with the tongue and groove to join in the middle. Last edited by vince1; 09-26-2019 at 11:41 PM. |
Pressure Treated might start to rust/dissolve the steel?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
I used exterior grade plywood. 2 sheets split down the middle with the the original strips refurbished and layed on top. I cinched it all down with carriage bolts thru the top and used washers and nylock nuts below. This job was done with 5/8" because it doesn't haul much heavy stuff. I have used 3/4 before too but it makes the strips stick up just a tiny bit above the rear cross sill, which is fine as long as you remeber that and don't go raking a sheet of drywall or similar vulnerable cargo over the raw edges. Also, for anyone thinking of doing a longbed truck, it will need 9 foot sheets which are availabe at real lumberyards.
For a temporary bed until I can get nice wood I used non treated plywood on mine and sealed it myself. It started to warp in less than a year, but other than that it is plenty strong enough and has held up for occasional hauling.
1966 c10 1937 Willys truck |
![]() Join Date: Jan 2011
I use mine as a truck and haul all kinds of stuff. I have white oak in mine and the stainless bed strips. Works good. The bed strips make it easier to slide stuff in. I am getting ready to redo my old 66 C20 and we are using the southern yellow pine in that one. Was cheaper than the 2 sheets of Marine plywood we would have needed.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Plywood from Lowe’s. Took this pic right before I bolted it down.
I used 2 sheets of regular 3/4" tongue & groove plywood in my longbed. I primered it, and then sprayed it with rattle can bedliner.
I relocated the gas tank in the bed, and found that regular exterior paint didn't like any gas splashing on it. It has held up really well for over 5 years now. I ran a bead of silicone down the seam in the middle just for peace of mind. I don't drive it a lot in the weather, but I have hauled stuff in it and it is still in really good shape. I do have the gap at the back that I didn't fill in with anything. Last edited by rcg66; 09-27-2019 at 12:40 PM. Reason: added photo |
I did the same as above and then put the original strips back over top of it. Let me see if I can find a picture somewhere.
#11 | |
But Found Her 25yrs Later!
Sorry, I don't remember. That was over a decade ago.
| Bookmarks |
