#51 |
Re: New C50 Owner
I just noticed your comment in your signature. Did you try super-tuning your 292?
The 292 in my '64 C-30 got somewhere around 12-15.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
#52 |
Re: New C50 Owner
I had rear wheel cylinders leaking as well, just soaked them with brake clean and wiped them down a couple of times. Your shoes like they have very little wear. Here is a picture of mine after cleaning.
#53 |
Re: New C50 Owner
Haven't done anything to the motor. Goal is to get it roadworthy, then to the shop for the frame shortening. After that work is done, we start on the little stuff.
Daily Driver: 2005 Chevrolet Silverado 3500 Dually 6.6L LLY Duramax Diesel and an Allison 5 Speed Currently looking for an Action Line truck, specifically 1969-1970, in very good condition. Longbed only, step or fleetside, or flatbed if C30. Must be unmolested (not modded). |
#54 |
Re: New C50 Owner
Those look pretty clean. No grabbing problems after reassembly?
#55 |
Re: New C50 Owner
None! Given the price it is well worth trying. I suspect yours will clean up as well. We used to clean semi brake shoes all the time after a wheel seal failure. They were very nasty but cleaned up just fine. Might need a couple applications of brake clean to get it all off.
#56 |
Moderator
![]() Join Date: Aug 2017
Re: New C50 Owner
Nobody makes/sells the gm 15x5 brake shoes anymore. I've called several places over the past year and no one could help. I plan on sending my rear shoes to this local company to be relined.
http://www.cecofriction.com/index.html Centric brakes makes 14x2 shoes for the front and dorman still makes all the rubber brake lines. Raybestos still makes wheel cylinders (although made in China) and can order them from Rock auto. If you need any help with part numbers just let me know.
Alex 1967 C50 292ci Lumber truck 1967 C50 292ci Dump truck 1967 C60 366ci Fire truck |
#57 | |
Re: New C50 Owner
Right now, my biggest concern is the inner wheel seal.
#58 |
Moderator
Re: New C50 Owner
3974846 is the original GM part number for 1969 c50 with 2 speed rear axle
370106A is the updated timken/national/federal part number Gmpartswiki.com will be your best friend after this ![]()
#59 |
Moderator
Re: New C50 Owner
Dorman H38908 is the brake hose from master cylinder to the frame for my 67 and It looks about the same as your 69.
#60 |
Re: New C50 Owner
CarolinaHD, you are on your way to becoming my new best friend!
#61 |
Re: New C50 Owner
I'm also trying to figure out what rear axle I have. The SPID says it's a T150, but the casting numbers Google a T170.
![]() BTW, what does SPID stand for? Sticker Placed In Dash???
#62 |
Moderator
Re: New C50 Owner
Thanks! Just trying to do my part to keep these old trucks on the road!
Spid= Service parts identification Post up a pic of it and the vin
#63 | |
Re: New C50 Owner
#64 | |
Re: New C50 Owner
#65 | |
Re: New C50 Owner
Please pass a long the part numbers if you wouldn't mind. I need to replace all mine. |
#66 |
Moderator
Re: New C50 Owner
The following is for a 1967 c50 with 5000lb front axle, 15,000lb 2 speed vacuum shifted rear axle, and midland vacuum brake booster.
Front 14x2 shoes- Centric 111.02990 Rubber brake hose master cylinder- Dorman h38908 Rubber brake hose front wheels x2- Dorman h36697 Rubber brake hose rear axle- Dorman h71305 Brake master cylinder- Dorman m630823 Front right brake wheel cylinder- Raybestos wc19091 Front left brake wheel cylinder- Raybestos wc19090 Rear brake wheel cylinder x2- Raybestos wc37159 Rear brake wheel cylinder x2- Raybestos wc37160 5000lb front axle kingpin rebuild kit NO REAM- Stemco k51g Moog plastic bushing kingpin rebuild kit- 8492n Kingpin thrust bearing- timken t110 Front wheel bearings x2- timken 3578a and 15103s Front wheel bearing race x2- timken 3525 and 15243 Front wheel seal- timken 8975s Rear wheel bearings x2- timken 3982 and 33287 Rear wheel bearing race x2- timken 3925 and 33472 Rear axle vacuum shift diaphragm- Bendix 374451 Should be about everything except rear wheel seal, rear shoes, and brake spring kits. All axle related parts are the same for 1965-1974 4000, 5000, and 7000lb front axles.
Alex 1967 C50 292ci Lumber truck 1967 C50 292ci Dump truck 1967 C60 366ci Fire truck Last edited by CarolinaHD; 04-02-2020 at 10:08 AM. |
#67 |
Re: New C50 Owner
#68 | |
Re: New C50 Owner
No problems at all, except a little while later was coming off a long steep mountain pass with a 10x50 mobile home behind. That side did some smoking so I guess I burned off the rest of the gear oil residue ![]() Hauled logs with the truck for about five years after that and never did another thing with the brakes.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
#69 | |
Re: New C50 Owner
#70 |
Re: New C50 Owner
You're welcome. Of course my 1965 c/50 wasn't all that "old" back then as that was 1982 I think
#71 |
Re: New C50 Owner
Final update. Got new wheel cylinders installed, new brake lines, cleaned the brake shoes with Brakleen as Airdirect suggested and everything worked perfectly.
After hounding the guy who said he would do the modifications for me for 7 months, I took the truck to two different shops to get estimates. WAY out of my price range. So, with a touch of bitterness, I sold the truck. I no longer own a pre-'72 truck!
