02-03-2020, 10:41 AM | #126 |
Re: 1967 C-50 Dump truck Project
I'll also add that most power steering pumps on our medium duties are the Saginaw 143 model (I think OEM #:7840099). This pump has great specs and are somewhat desirable in the off-road community.
Per 0086 parts, this pump is able to produce 1595 psi and 4.2 gpm Hope that helps! |
02-06-2020, 10:43 AM | #127 | |
Again thanks for being a big contributor to this build! I'm gleaning as much information as I can from your knowledge! |
02-19-2020, 12:03 AM | #128 |
Moderator
http://67-72chevytrucks.com/vboard/s...59#post8680859
Did the best I could on my phone, my pics are always sideways. I'll make a build thread at some point..
Alex 1967 C50 292ci Lumber truck 1967 C50 292ci Dump truck 1967 C60 366ci Fire truck |
03-08-2020, 07:52 PM | #129 |
Moderator
Going to atlanta and kentucky this week to pick up 2 c50s. Let me know if you need any parts.
03-09-2020, 09:07 PM | #130 | |
Also Thanks for all the information on the hydro brake setup. |
03-09-2020, 09:09 PM | #131 |
03-09-2020, 09:10 PM | #132 |
Moderator
As in mutiple c50, 67 and 69. Sorry bout that
03-09-2020, 09:14 PM | #133 |
Ok I have an idea in the back of my mind to try and piece together a decent C/50 truck with my left over parts and running gear. I'll probably update this in project with in the hour. I just got home and need to take care of a few things before I get on the computer. I just wanted to respond your reply about parts.
03-10-2020, 06:09 AM | #134 |
Moderator
10 4 I'll let you know when they're in my possession
04-01-2020, 09:36 PM | #135 |
04-01-2020, 09:58 PM | #136 |
So it's been awhile since I last posted an update. Things have been busy with my transportation company and my shop. last summer I bought a piece of land so I could build a bigger shop. So a few weeks ago we broke ground and started laying out the driveway. Man, what a mess. It had never gotten cold enough these last few months for the ground to freeze and we got tired of waiting. So I'll add some photos of that progress. I also used my 1977 GMC 3500 grain truck to haul several loads of rock to help get the driveway started.
I have done a little work on the Kansas cab. I also went to the local medium duty truck shop where I used to work to look for a Top Kick Electric/Hydro Boost. I did find one but haven't went back to grab it yet. I've been going over the body panels and taken a mental note of what needs done. |
04-01-2020, 10:00 PM | #137 |
Here is the photos of the progress on the new property.
04-01-2020, 10:12 PM | #138 |
I've been kicking it around the idea of doing a 12 valve swap and as mentioned in my first post, I intend to use this truck both for the farm and the local stone quarry. A quick little story that goes along with this next update: I have a friend, who works at our local school as a bus mechanic, ask me if I would be interested in becoming a substitute bus driver in all of my spare time...
I said why not. So I went through the classes and was ready to do all the driving tests, then the pandemic hit. So much for that... Anyways, during the time of turning in paperwork and in general, just stopping by the bus garage to hang out, I was told about a bus that had a 12 valve cummins with a newer rebuild on the engine. So I asked how much and it was a bid kinda thing. So as of yesterday, I became the owner of my old high school band bus.... I'm not a 100% sure just how the project will go from here on out but I know I will figure out the best route for my needs before too long. |
04-02-2020, 08:09 AM | #139 |
Moderator
Awesome looks like you got plenty of work cut out for you! This virus crap shutdown my plans of getting those other 2 trucks but I still plan on getting them this summer.
04-02-2020, 08:10 AM | #140 |
Moderator
Copied this from the other thread.....
The following is for a 1967 c50 with 5000lb front axle, 15,000lb 2 speed vacuum shifted rear axle, and midland vacuum brake booster. Front 14x2 shoes- Centric 111.02990 Rubber brake hose master cylinder- Dorman h38908 Rubber brake hose front wheels x2- Dorman h36697 Rubber brake hose rear axle- Dorman h71305 Brake master cylinder- Dorman m630823 Front right brake wheel cylinder- Raybestos wc19091 Front left brake wheel cylinder- Raybestos wc19090 Rear brake wheel cylinder x2- Raybestos wc37159 Rear brake wheel cylinder x2- Raybestos wc37160 5000lb front axle kingpin rebuild kit NO REAM- Stemco k51g Moog plastic bushing kingpin rebuild kit- 8492n Kingpin thrust bearing- timken t110 Front wheel bearings x2- timken 3578a and 15103s Front wheel bearing race x2- timken 3525 and 15243 Front wheel seal- timken 8975s Rear wheel bearings x2- timken 3982 and 33287 Rear wheel bearing race x2- timken 3925 and 33472 Rear axle vacuum shift diaphragm- Bendix 374451 Should be about everything except rear wheel seal, rear shoes, and brake spring kits. All axle related parts are the same for 1965-1974 4000, 5000, and 7000lb front axles.
Alex 1967 C50 292ci Lumber truck 1967 C50 292ci Dump truck 1967 C60 366ci Fire truck Last edited by CarolinaHD; 04-02-2020 at 10:07 AM. |
04-02-2020, 10:33 PM | #141 |
04-02-2020, 10:33 PM | #142 | |
