Old 04-03-2020, 03:51 PM   #1
SSSilverado
SSSilverado's Avatar
81-82 grille side molding retainer clips
Hi, longtime lurker here, but I really enjoy this site. I'm near to end rebuilding my 82 Silverado. I've had it for 25 years and spent the last 3+ rebuilding it. I will upload more photos, if I can figure out the build thread.
I still have my original grille trim, I cleaned and installed, but I'm trying to find the clips that go behind fenders for grille side molding trim, near headlights. The studs for the side trim have an end cap on them and are not for nuts, but rather a clip of some kind. They've been gone so long I don't remember what they looked like. See images attached. Could someone help with what they are called. Summit has many that look close, but not sure. Thank you.
I'll have some spare parts when all this is done, not in the best shape, but they could help somebody.
SSSilverado is offline   Reply With Quote
Old 04-03-2020, 09:39 PM   #2
TKCR
TKCR's Avatar
Re: 81-82 grille side molding retainer clips
Have you looked at clipsandfasteners.com? I have had good luck in finding clips & grommet, that are hard to find.
Old 04-03-2020, 11:07 PM   #3
SSSilverado
Thanks, that's a great site, all kinds of stuff. I found one on their catalog page might be it. GM part# 14022878.
http://www.clipsandfasteners.com/v/v...catalog410.pdf
Maybe not in stock on their site, but it helped me find the #. Thanks!
https://www.classicindustries.com/product/14022878.html
https://shop.northlandfasteners.com/...lip-N12621.htm
Old 04-04-2020, 07:36 AM   #4
TKCR
TKCR's Avatar
That does look like it.
Old 04-05-2020, 08:02 AM   #5
Pontiac1976
Pontiac1976's Avatar
I found there is two types, but most I have seen have been that type GM part# 14022878.
I have found one other type as being steel I pick them up in a yard. When I had to take out a grill to make it easy to get to the pulleys crank bolt. never seen any other one like them.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
