Old 03-29-2020, 11:40 AM   #276
Kronald_70GMC
Kronald_70GMC's Avatar
Re: My 1970 GMC Project
Originally Posted by TA_C10 View Post
I'm keeping my kick panel vents for that same reason. I don't want to have issues, and sometimes it's beneficial to have fresh air come in.
Windshield looks great. I should have done that one too since it's going to be my DD and I'm a little worried about windshield leaks.
I thinking that if I was to make a delete plate from the outside while I have the cowl off that had a couple of louvers in it it would probably give me enough and not be too noisy. I'm still undecided on this, I dont even know how I'd go about punching louvers.
As for the windshield, as long as you get those seams filled up nicely with some sort of seam sealer, I think you would be fine. I didn't even think to much on that, I was more motivated to have my drip rail appear seamless all the way around. I suppose it probably would be helpful in the leak department as well.
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
Kronald_70GMC is offline   Reply With Quote
Old 03-29-2020, 04:13 PM   #277
Kronald_70GMC
Well I guess that answer that question. I spent the morning making a die for hammering out some louvers. I think if I was to have three louvers in each side, it should be able to pull enough fresh air through for everything to remain happy. I'm hoping that it will also double as a pressure relief for closing the doors as this would allow me to remove the one in the drivers door jamb for a cleaner look.
Oh and cornerstone, I've included pics of my grinding arsenal if your interested.
Kyle
Old 03-30-2020, 02:31 PM   #278
Kronald_70GMC
I have figured out how I'm getting my wiring into the engine bay as well. Thanks to TA C10 for linking me to a thread about these. I'm just unsure if I will need all 3 or just the two. I guess I'm going to have to order a wiring harness soon so I will know for sure.
Kyle
Old 03-30-2020, 03:33 PM   #279
TA_C10
TA_C10's Avatar
I love those louvers! Nice work. And I'm excited to see how your wiring turns out. It's gonna be sweet hidden like that
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 03-30-2020, 04:39 PM   #280
Kronald_70GMC
Thanks man! I'm also excited to see how my wiring is gonna turn out. That would mean I'm done the cab.
Kyle
Old 03-30-2020, 10:13 PM   #281
Kronald_70GMC
Well that escalated quickly. Turns out I wasn't able to fit 3 of those seal tight elbows on the one side. Then I got to thinking, why not put 2 on both sides? That way I can even run an amp power wire up through one of them on the passenger side. Plus you never know when you might need to snake a wire through for something.
Kyle
Old 03-30-2020, 11:36 PM   #282
TA_C10
TA_C10's Avatar
Great idea, always provision for extra. Now your gonna have to start thinking about door wiring lol.
"It's only money".
Old 03-31-2020, 12:26 AM   #283
Kronald_70GMC
I'm not sure there will be any door wiring. I think I'm gonna stick with crank windows and manual locks. Although there is plenty of time for me to change my mind.
Kyle
Old 04-02-2020, 11:00 PM   #284
Kronald_70GMC
Today I pulled the trigger on a wiring harness so that I could get it all mounted up from the inside. It is a 21 circuit E-Z Wiring kit that I picked up locally for $375. Seems to be pretty good quality and I'm quite happy with it.
Kyle
Old 04-03-2020, 12:54 AM   #285
TA_C10
TA_C10's Avatar
I've heard those kits are good quality. And a quick tip I learned. Install your fuses last. Turn on the ignition. Plug then in one at a time. If one pops, you know where to look/trace.
"It's only money".
Old 04-03-2020, 08:57 AM   #286
Kronald_70GMC
Thanks for the tip. Makes good sense to me.
Kyle
Old 04-04-2020, 10:21 PM   #287
Kronald_70GMC
I spent the afternoon in the shop today. I managed to get the passenger side of the cowl fitting much better. From factory, it was almost as though the piece was formed incorrectly. It was twisted towards the front of the cab and sticking out to far to the side. I assume that is why there were SO MANY SPOT WELDS on this side. I had to make two relief cuts but it is sitting much better now.
Kyle
Old 04-04-2020, 11:34 PM   #288
cornerstone
cornerstone's Avatar
Another fine repair! I gotta ask... How do you get your metal so freakin clean?! It practically looks like surgical steel!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 10 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 04-05-2020, 12:52 AM   #289
Kronald_70GMC
Haha I have a black, very course puck type of paint stripping wheel on a drill as well as a wire wheel attached to a drill. I like the shine it gives, it makes it easier to find lows and highs so I can address as much as possible before I do any filler.
Kyle
Old 04-05-2020, 12:53 AM   #290
Kronald_70GMC
This is the one here
Kyle
Old 04-05-2020, 03:23 AM   #291
Scurry67
Looks awesome man! Really enjoying all the firewall pictures. I added the round corner on mine to make it look more symmetrical, but you took yours to another level. Keep it up!
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 04-05-2020, 12:05 PM   #292
Kronald_70GMC
Thanks for the compliments. I'll have to check your build out.
Kyle
Old 04-05-2020, 10:03 PM   #293
Kronald_70GMC
Today I got the last hole from the original heater fan filled in. I also cut out the small reinforcement plate for the corner of the cowl and cut/welded in a new piece to mimic the driver side. I still have to add the flange from cowl to cab so I can install it but I am getting close.
Kyle
Old 04-05-2020, 11:45 PM   #294
TA_C10
TA_C10's Avatar
Looking great!
"It's only money".
Old 04-06-2020, 01:08 AM   #295
Kronald_70GMC
Looking great!
Thanks. I see you have been making good progress on yours as well. Keep it up!
Kyle
Old 04-07-2020, 10:53 PM   #296
Kronald_70GMC
I have finished the re constructive surgery on the passenger cowl tonight. Looks damn near like the other side now. Next I've got alot of welding ahead of me, all of my spot weld holes are much to big to plug weld nicely so I have flattened off and folded over the end of a copper pipe so I can weld all the old holes shut and drill new ones. Another reason that im happy I have removed my cowl is that now I will be able to get the wire gutter much straighter when I weld it back on. That one picture shows just how far off it was before. That mark in the center of the hole was the edge of my spot weld cutter.
Kyle
Old 04-11-2020, 08:16 PM   #297
Kronald_70GMC
Oh boy was that ever fun! Welding 100 holes shut just to drill 100 smaller ones. I'm very close to getting my cowl back on now. I've busted out the brush on seam sealer and sealed all the seams under the cowl. Now it's just some weld through primer, then some paint and then I can begin the 100 plug welds, though I'm probably only going to get about 10 in before I run out of shielding gas. Oh well the weather is starting to smarten up around here finally so I can always start taking the front end apart and get ready to mock up for cab corners and rockers.
Kyle
Old 04-11-2020, 08:52 PM   #298
chewychevy67
That looks sharp. I'll bring my cab over next lol.
chewychevy67 is offline   Reply With Quote
Old 04-11-2020, 09:24 PM   #299
Kronald_70GMC
Haha I've got the whole rest of my truck to finish first. How is your engine coming along?
Kyle
Old 04-11-2020, 09:36 PM   #300
chewychevy67
I am going to change the oil pump. Don't like the noise it makes. So in other words slow
