Sending unit ground wire
Trying to put my truck together and it has no wires at all going to the gas tank. I was going to order the wire that goes from the fuse box to the tank itself. My question is, where do you have the ground wire on your gas tank/cab?
Re: Sending unit ground wire
Perhaps you mis spoke with the fuse panel. It's my understanding that on the tank, Ground lug is connected to any good chassis or body ground location. Sender lug is connected to guage, power wire is connected to other side of guage. There should be no power going to tank.
Not knowing what you have, perhaps you have an in tank fuel pump.
Brent W 66 short step 4 x 4 |
#3 | |
#4 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#5 | |
Old member
Welcome sir!
Well apparently I'm quite wrong on this, glad you got the right stuff, wiring diagram to boot.
The Older Generation
Here are some large wiring diagram image files. http://67-72chevytrucks.com/vboard/s...d.php?t=185856 Below the small wiring diagrams you will see links to the larger diagrams, click on those. The wiring shown for the windshield wipers is wrong on those diagrams so you will have to look at the image in post #67 (on page 3) of this thread for the correct wire color and plug orientation for the wiper/washer. http://67-72chevytrucks.com/vboard/s...d.php?t=413551 LockDoc
#9 | |
![]() Join Date: Nov 2019
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
Service manuals are great tool to have
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
