![]() Join Date: Jan 2018
Trailing Arm Bushing - Hole Saw?
I have a ton of time to work on the truck now so I am doing all the projects I have been meaning to for months. Anyways, next up is replacing the trailing arm bushings. Rather than drill or burn them out, has anyone ever tried to use a hole saw larger than the inner sleeve but smaller than the outer sleeve to cut the rubber out?
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
Re: Trailing Arm Bushing - Hole Saw?
Hole saw might work. A sawzall might work too. I have used an air chisel (muffler gun) with a blunt end and smash the outer shell inwards, compressing it, allowing it to be driven out easily.
![]() Join Date: Dec 2012
I used a drill bit barely smaller than the rubber itself and drilled the rubber multiple times to weaken it. It comes out really easy doing this. I imagine the same effect would happen with the hole saw, but it’s a 5 minute job with a drill and drill bit. Then just drive out the metal bushing with a hammer and then the rubber all but falls out.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
#4 | |
I did the old school heat it with a simple bottle torch and squish the center out. Only took about 10 minutes to get the center and rubber out, the outside shell was a different story.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
ball joint press will push them right out
Fuzzy |
#8 | |
This link has some pictures at the bottom. Trailing arm bushing thread
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green Last edited by KMC3420; 04-07-2020 at 11:20 AM. |
You know it! Reminded me of this line from a very good song: "You could smell the whiskey burning down copperhead road."
Cebra - you got them things out yet? If so, what was your method?
![]() Join Date: Feb 2016
Are you asking how to remove the bushing from the arm or how to remove the inner sleeve from the bushing?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
