Old 04-10-2020, 04:33 PM   #1
71gmcC15
71gmcC15's Avatar
Re: What have you learned new about these truck recently.
Originally Posted by bigdog55 View Post
I have been slowly fixing my GMC. There are alot of parts that are interchangeable between The chevy's and GMC but not everything. And every so often I find something that won't inter mix. Like I have been changing my lights and turn signals over to LED's. They do not make a LED for my front turn signals. They also don't repop the housing for them, at least I haven't found any.
They do make the housing lmc has them. They dont make the plug for the light though. ( I know I need one) might have found one but haven't ordered it yet. As for the LEDs I have a set made by rob. The first ever set actually. Not the first installed. But are with clear lenses.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 04-10-2020, 06:38 PM   #2
best view
That u could order your blazer yellow and it showed up at the dealer orange
best view is offline   Reply With Quote
Old 04-10-2020, 07:01 PM   #3
best view
Old 04-10-2020, 10:03 PM   #4
jocko
jocko's Avatar
Hey, you gotta elaborate on that one... Are you talking about the orange Blazer that looks 100% original paint and has light yellow on the SPID? (it also had avocado plaid trim I believe) Or at least that's what it was ordered with, dunno if it showed up at the dealer that way or if the factory just built the original owner a totally different blazer than he asked for. Anyway, if none of this rings a bell... pls disregard
Old 04-10-2020, 10:58 PM   #5
ls1nova71
ls1nova71's Avatar
That had to be a typo or just the wrong SPID for that particular truck. I know that happened because I have the glovebox door off a friends Custom30 truck that was medium green but it says it was a light red Cheyenne
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-10-2020, 11:09 PM   #6
HO455
HO455's Avatar
That there are 3 or more versions of factory bench seats that came installed over the years and that there are 3 different seat mounts of different heights and that's not counting the C40-C60 later versions that look very similar.
RIP Bob Parks.
Old 04-13-2020, 10:41 AM   #7
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Interesting. I knew there are at least two different types of seat adjusters, one set is taller.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-14-2020, 06:18 PM   #8
HO455
HO455's Avatar
FYI
http://67-72chevytrucks.com/vboard/s...d.php?t=510997
RIP Bob Parks.
Old 04-14-2020, 12:47 PM   #9
maverickmk
I learned on Sunday that my truck doesn't stop very well without any liners on the rear shoes
maverickmk is offline   Reply With Quote
Old 04-13-2020, 05:24 PM   #10
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I learned that the door seals that go between the front fender and cowl are not exclusive to 71-72 Cheyenne Supers and were also put on the 71-72 Cheyennes as well and I realized that the 1970 CST I had had them on too.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 04-14-2020, 07:26 AM   #11
71gmcC15
71gmcC15's Avatar
I learned yesterday that's the tilt column horn contact is different then the non tilt. Not shure why.
Old 04-17-2020, 05:01 PM   #12
MACO
MACO's Avatar
My 69 C20 also has these seals.
1969 C20 Customer Camper CST, 396, TH400, Factory A/C, Olive Green.
MACO is offline   Reply With Quote
Old 04-10-2020, 11:18 PM   #13
Steeveedee
Who Changed This?
Steeveedee's Avatar
Heh, a couple of friends ordered a (whatever it is that Dodge makes that looks like a Blazer) in some purple, without the back seat, because they had no kids. It showed up orange with a back seat and options they didn't want. I think that the salesman just pulled up something from the back lot after they ran out of patience. The wife chewed the salesman up one side and down the other, but they ended up taking delivery on it, anyway! I'dve had my money back, or a real piece of that salesman's hide.
~Steven
Simi Valley, CA
