Old 04-10-2020, 09:48 PM   #10
Captainfab
60-66 Nut
Re: Starting 1966 Factory Short Bed Build, Bagged, 383 Stroker and Muncie M20 4-Speed
With the steering box located using the included template, the stock draglink should not be touching the crossmember with the idler arm in it's original location. Do you have the pitman arm on all the way? And the pitman arm is something special from POL?
