Old 04-09-2020, 06:38 PM   #1151
youngrodder
youngrodder's Avatar
Re: 53 Surburban "Family Truckster"
Originally Posted by doowoppwer View Post
looks really nice. i'm along for the ride. roger
Glad to have you along for the ride Roger, grab a seat...ha ha
Originally Posted by joedoh View Post
that raw steel color looks great on the ivory.
Thanks it always a bit of a crap shoot but I am very stoked on how the two colors look next to each other in combination of the gloss and satin finishes.
Originally Posted by 84blaze View Post
Killer work. What is your username on Instagram again?
greenfield_speedshop There's a story behind the name ..
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is online now   Reply With Quote
Old 04-09-2020, 06:53 PM   #1152
youngrodder
So I have been working from home for the last few weeks so one would think lots of garage time. Its been just the opposite. When the economy is bad our company gets very busy. We are a flexible printer for consumable packaging.
Here are some recent progress...I installed the Altman easy latches. I realized that the striker plate will take some modifications as my doors are 47-50 but my body is a 53. The bad part is the striker plates were already painted....
I also took some new chrome door handles and gave them a satin finish. I love how they turned out. I think it goes with the over all theme better. After seeing how well the door handles turned out I plan to treat all of my chrome to this satin finish....more to come.
Stay safe/healthy out there......
Old 04-11-2020, 09:13 PM   #1153
youngrodder
Got a little more done on Friday and Saturday. I modified one of the striker plates from my Altman easy latch kit.The other side should go quicker. Once modified, I will repaint them. I created a small bracket for the throttle cable. Happy with how it turned out. I threw on my air cleaner to see what the finished product will look like. Waiting on some fuel rail brackets that should show next week then I can finalize my fuel supply all the way up the the throttle body.
On Friday I got my injectors back from being cleaned and the screens and O-rings changed. I learned the hard way on my 48 that injectors get gummed up when sitting. This can complicate the trouble shooting process on the first start up. They provide you with readouts of before and after too see how the injectors are working. I had one that was not working at all but after several back flushes they got it firing. So that was $$ well spent.
Lastly on Saturday my sound deadening material showed up so I got busy installing that.....
tomorrow I will sand blast and rebuild one door hinge
Marc
Old 04-11-2020, 09:14 PM   #1154
youngrodder
One more of the sound deadner install.
Old 04-11-2020, 09:27 PM   #1155
mongocanfly
mongocanfly's Avatar
Great job on the deadner..looks rsally nice...what you do to the chrome?..scotchbrite?
And who'd you send your injectors to?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-11-2020, 11:50 PM   #1156
oldman3
oldman3's Avatar
Nice job with everything...Jim
oldman3 is offline   Reply With Quote
Old 04-12-2020, 08:46 AM   #1157
youngrodder
Thanks, yes scotchbrite with a little penetrating oil applied to the pad. The place is in Michigan (my same state) so I choose Performance Fuel Injection Systems out of Elsie, MI. it cost $96.00 + shipping one way. There's a bunch of places on eBay that offer this service. It was $12.00 per injector. Besides the injector readout they also supply a little baggie with all of the stuff they replaced. It provides a nice visual of how junked up some of the screens really were.
Thanks Jim, I'm trying.
Old 04-12-2020, 08:52 AM   #1158
8man
Truck is looking good.
Wish Altman listened when we ordered!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 04-14-2020, 03:32 PM   #1159
Scott2
You are clearly just slightly anal! That looks awesome! However, now you've created a big dilemma for me! I'm just about to lay down the Dynamat in my '79 Jeep J10 cab and I assure you it wasn't going to be that precise. But the picture in my head of a good job is your pic so now I have to rethink this part of the project. Damn!
Seriously nice work though.
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 04-15-2020, 11:53 AM   #1160
youngrodder
Scott...yes I am..ha ha. I'm always happy to create more work for others...I will probably go up higher on the firewall but I need to add some metal to hang the wiring panel from and I my gas pedal mount. I started with full sheets then filled in the open areas and took time to trim to fit. It was not bad at all.
Marc
Old 04-16-2020, 05:30 AM   #1161
84blaze
Will you be sound deadening the complete roof skin? I think that'll make a huge difference if you do.
84blaze is offline   Reply With Quote
Old 04-16-2020, 08:20 AM   #1162
youngrodder
Yes I plan to but I might use a different product with more insulating properties. More research is needed on what I'll buy.
Marc
Old 04-16-2020, 08:45 AM   #1163
youngrodder
Last night I worked on mounting my ECU under the seat. I had to notch thhe edge of the seat opening slightly to allow the computer to slid back some....I cut a 2.25" pass thru hole for the rubber grommet. I also used these simple ECU mounts that grab the ECU on the sides. To fasten these to the floor, I used nut zirts that I think are slick. Also while I was at it I needed to get a sneak peak of my gauges....I still need to make a small bracket to mount a small fuse panel from the LS (BP Automotive) wiring harness.
Marc
Old 04-16-2020, 08:46 AM   #1164
youngrodder
A few more pics...
Old 04-16-2020, 09:01 AM   #1165
8man
Looking good!
8man-aka Robert
Old 04-16-2020, 07:19 PM   #1166
joedoh
joedoh's Avatar
are those the coyote swap 5" DD gauges? I noticed those a couple months ago and I like how they fit the hole. the 47-53 DD gauges use an adapter ring and for expensive gauges I just think thats... low effort?
if so, thanks for showing me what they look like!
Old 04-16-2020, 08:16 PM   #1167
mongocanfly
gauge looks great Marc ...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-16-2020, 10:45 PM   #1168
youngrodder
These are just the HDX gauges by DD for AD trucks....Nothing special just expensive but they are expandable. I added an ambient temp sensor.
Thank you. I wavered between Silver or White...
Old 04-17-2020, 12:54 AM   #1169
joedoh
joedoh's Avatar
ahh the ring looked different. the stock appearing ad DD stuff is nice but why couldnt they make it fit?
this is the coyote swap set I looked at.
fit a 5" hole but from the front, which is nice when you have a lot of stuff in the dash like I do.
you will have to tell me how you like them!
Old 04-17-2020, 07:40 AM   #1170
youngrodder
I'm not sure what doesn't fit. On mine, yes you have to install from the back side but they fit the holes opening fine. They fit just like the last set of all digital DD I ran in my 48 truck..To me the lip on the Coyote swap as you are referring to them. The lip looks too big and seems like it would look out of place. Not to mention how would you secure them to the dash since they would not use the stock mounting locations.
I will let you know
Marc
Old 04-20-2020, 10:35 AM   #1171
youngrodder
I picked up my painted seats from the painter. One (middle) had a sizable run in the clear so I took it back to be fixed. I think the white seats frames in gloss with offer some nice contrast to interior. I also installed a Newport Engineering wiper motor. Moving forward.
Marc
Old 04-22-2020, 07:18 AM   #1172
84blaze
Marc, how did the install of the Newport engineering wiper motor go? Do you think it's worth the money? Will you be retrofitting the factory knob onto the switch?
Spencer
Old 04-22-2020, 11:29 AM   #1173
youngrodder
Spencer
It was pretty straight forward. I did extend the lower brace to reach a factory hole in a factory bracket under the dash. I also clearance the housing some as it hit the linkage of the fresh air vent. Mine was moved slightly. My dash is modified since I cut the bottom of the dash flat to later add a lower dash panel to I don't know if those changes are due to my other dash changes. I didn't mount the switch yet but it wont be in the stock location as I filled that hole. Goes with my less is more design beliefs. I will probably hide it under my lower dash panel. I have an idea. I plan to drive mine a lot so I wanted good wipers in case I get into some heavy rain...
I can grab some pics if you like.
Marc
Old 04-23-2020, 05:05 AM   #1174
84blaze
Marc
Right on! I would love to see some photos of the install when you get a chance.
Old 04-23-2020, 08:29 AM   #1175
youngrodder
You've got it. I'm waiting on a cowl vent seal then I'm going to reassemble everything and get the vent working smoothly (to make sure no other modification are needed)....
Marc
