Old 04-11-2020, 09:42 PM   #301
Kronald_70GMC
Kronald_70GMC's Avatar
Re: My 1970 GMC Project
Originally Posted by chewychevy67 View Post
I am going to change the oil pump. Don't like the noise it makes. So in other words slow
Yeah I saw that. That's not very cool. At least you found it before the engine was installed.
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 04-11-2020, 10:17 PM   #302
TA_C10
TA_C10's Avatar
Great milestone. Looks really good Kyle.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 04-11-2020, 10:29 PM   #303
Kronald_70GMC
Thanks TA, I got the weld through and the paint all wrapped up tonight. Tomorrow I will start welding it in. I wont get very far with my small amount of gas but at least it will be a start.
Kyle
IG: kyle_ronald
Old 04-12-2020, 03:53 PM   #304
Kronald_70GMC
Hmm, who would of thought that when you welding gas gauge is almost at 0, that you could still do 100 spot welds? Awesome news for me as I just finished welding my cowl back into position! So excited to see it back on and looking so clean.
Kyle
IG: kyle_ronald
Old 04-12-2020, 04:11 PM   #305
chewychevy67
Nice. Are you going to remove the outer roof panel to clean it up under there and check for thin metal and paint as well?
chewychevy67 is offline   Reply With Quote
Old 04-12-2020, 04:18 PM   #306
Kronald_70GMC
I was considering it but if I stick my finger up into the visor hole as far as I can reach, there is nothing but smooth clean metal so I think I'll leave that part alone.
Kyle
IG: kyle_ronald
Old 04-12-2020, 04:20 PM   #307
chewychevy67
My cab has holes from cab lights and I have a new roof panel so I may just change it. Not looking forward to that one.
Old 04-12-2020, 05:53 PM   #308
Kronald_70GMC
One of my friends had removed his roof panel from his cab. It wasn't too bad. He even had done it in a way that he could have used the original. Then he went and quit the project and scrapped it. If you do it, I assume that you will be welding the rear roof seam? Being that there is no other option.
Kyle
IG: kyle_ronald
Old 04-12-2020, 06:17 PM   #309
Richard2112
Richard2112's Avatar
That's some good looking metal work right there. Cool ideas too.
Richard2112 is offline   Reply With Quote
Old 04-12-2020, 06:37 PM   #310
Kronald_70GMC
Thank you sir.
Kyle
IG: kyle_ronald
Old 04-13-2020, 11:50 PM   #311
Kronald_70GMC
I get one mod done and it it just leads me right into the next one. Maybe one day I'll get back to the rest of my rust repair. I have never been a fan of the wire gutter and I've seen many guys on here close it up and I just had to follow suite. It just finishes off the look the firewall so well IMO. Now just a few days of welding and grinding. Have a good one guys!
Kyle
IG: kyle_ronald
Old 04-14-2020, 12:23 PM   #312
TA_C10
TA_C10's Avatar
I need a popcorn GIF. I'm just sitting back watching you work the metal. Fantastic work.
"It's only money".
Old 04-14-2020, 12:45 PM   #313
cornerstone
cornerstone's Avatar
Originally Posted by TA_C10 View Post
Fantastic work...
Seriously. You are definitely a detail oriented guy, well, at least on this truck you are!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 04-14-2020, 05:11 PM   #314
Kronald_70GMC
Thanks guys! So awesome having an audience.
Kyle
IG: kyle_ronald
Old 04-16-2020, 01:30 PM   #315
H A M M
H A M M's Avatar
Just read the whole thread thanks to being slow at work. very nice work going on here.
-Scott
"If it jams, force it. If it breaks, it needed replacing anyways."
Build log coming........eventually.
H A M M is offline   Reply With Quote
Old 04-16-2020, 06:09 PM   #316
Kronald_70GMC
Haha I've been doing alot of reading on here as well for the same reason. Thanks for the compliments.
Kyle
IG: kyle_ronald
Old 04-17-2020, 01:40 AM   #317
Scurry67
I like your choice in mods. I wished I would have shaved the gutter. Your firewall is going to look so clean.. What's next on your to do list after the firewall mod?
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 04-17-2020, 08:58 AM   #318
Kronald_70GMC
Thanks, I'm pretty happy with how its turning out. Next I need to get all my front sheet metal so that I can install my rockers and cab corners and such. I want to have it all hanging to help with alignment.
Kyle
IG: kyle_ronald
Old 05-02-2020, 10:19 PM   #319
Kronald_70GMC
Well its been a little bit since I've posted. I have just about finished up grinding the gutter shave pieces down. Then things have gotten slow as I have been replacing our old, worn carpet in the house with some engineered hardwood that I scored for free from a friend of mine. Its used and has some light scratches but is MUCH nicer than the carpet. On top of that I've got some other house upgrades to do this summer like a new back door and a deck so work will be a little slower on the truck. I did manage to spend a good chunk of today working on the truck, just not on the cab. I ended up scoring a square body junker through a friend for $100. I kept the front crossmember and rear differential off of it. I'm going to use the newer style crossmember for the fact that it will give me rubber bushings on the control arms and disc brakes. It also came with 3 5 bolt rallies and the guy is going to get me a forth so I'm thinking of doing a 5 lug swap while I'm at it in case I want to upgrade the rims down the road. Since I have no pictures of my progress, I thought I'd throw one up of my dads 1969 CST that he put a 348 into. Enjoy. P.S Don't mind the dust and mess around it
Kyle
IG: kyle_ronald
Old 05-03-2020, 12:56 AM   #320
cornerstone
The chevy truck nut doesn't fall far from the tree, huh!? I see your dad has good taste in classic trucks also. What are his plans for it? It appears to be a beauty!
Brian
Old 05-03-2020, 01:01 AM   #321
chewychevy67
That garage looks familiar. Maby if all the paint pails weren't in the way of that driver side door he would drive that truck more.
Old 05-03-2020, 01:28 AM   #322
Kronald_70GMC
It is really nice. He completely restored it a few years ago but hasn't been able to drive it much because it has an oil leak and it is geared VERY high. Revs far to high for any highway driving. Hopefully he can get those things fixed up soon and drive it.
Haha I keep trying to get him to clean it up and fix the few issues. It needs to be driven! Lol
Kyle
IG: kyle_ronald
Old 05-25-2020, 01:01 AM   #323
cornerstone
Hey Kyle- I hope your making all kinds of progress and taking a ton of pictures... I could use some inspiration to get me back on my project!
Brian
Old 05-25-2020, 09:11 AM   #324
Kronald_70GMC
Haha I am making progress for sure, unfortunately though it is not on the truck. I've been very busy with renovations on the house. We needed a new deck as well as new flooring and paint. With any sort of luck, I might be able to jump back on the truck sometime in June.
Kyle
IG: kyle_ronald
Old 05-25-2020, 10:21 AM   #325
cornerstone
Looks like you are in the same boat as I am! The thing that bothers me is, since I'm not the most organized guy, every time I get a half of an afternoon to work on my truck, it takes me a solid hour of thinking to get me back on track and figure out what I need to do next. I admire guys who can juggle a hundred things and still be organized.
I'm still neck deep in a kitchen and bathroom remodel. We have guests coming to stay with us this Thursday for a week to 10 days so the push is on to wrap up the loose ends and get everything back in its place.
Your deck looks sweet by the way.
Brian
