Old 04-13-2020, 09:31 AM   #5
SCOTI
SCOTI's Avatar
Re: '73-'87 Control Arms are Tight
Originally Posted by Wrenchbender Ret View Post
Don't tighten the end nuts up until you have the arm in the center of the travel.
George
x2.
The A-arm shaft hardware @ the bushings is not supposed to be torqued to spec until there is full weight on the suspension. It still binds.... It is just closer to where everything should be.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
