Old 02-18-2020, 12:08 AM   #201
Graham57a
Graham57a's Avatar
Re: 1968 GMC Shorty - Pearl
One more piece I’ve been working on for the 327
Next step on the truck: I need to finish body work on the firewall and prep for new paint. Then I can throw the cab back on the frame and drop the motor in the frame as well. Just need to get my other projects in a good place so I can focus on this one haha
Graham57a is offline   Reply With Quote
Old 04-03-2020, 06:28 PM   #202
Graham57a
Graham57a's Avatar
Finally
Old 04-03-2020, 08:12 PM   #203
Kronald_70GMC
Kronald_70GMC's Avatar
That looks nice! All shiny on the bottom and patina on top.
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is online now   Reply With Quote
Old 04-14-2020, 09:12 PM   #204
Graham57a
Graham57a's Avatar
Gaining on her. Hoping to drop the cab back on the frame tomorrow if my cab bushings show up.
Old 04-14-2020, 09:15 PM   #205
KMC3420
KMC3420's Avatar
Awesome updates. Keep at it.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 04-15-2020, 08:39 AM   #206
Graham57a
Graham57a's Avatar
Thanks man, this quarantine has been good for truck progress
Old 04-15-2020, 09:33 AM   #207
gcburdic
Restoration Virgin!
gcburdic's Avatar
Looking good, Graham. Hope you are doing well! Looks like you've added several to the herd since i last saw you.
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-15-2020, 12:37 PM   #208
Graham57a
Graham57a's Avatar
Hey Geoff, things are going great! Hope you are well, it's been a while man. Yea I've been pretty lucky to acquire a few of these old trucks, I figure they are only getting harder to find right? I picked up a blue K20 recently that I haven't posted on here yet but shes another one on the list. More than likely that is what I will be driving to the PTS cruise in June.
Old 04-16-2020, 09:12 PM   #209
Graham57a
Graham57a's Avatar
Slight change of plans... again. Gonna make this one lay frame, I’ve always wanted to build a bagged truck so here she is. A little mock up today and started pancaking the crossmember
Old 04-16-2020, 09:58 PM   #210
Kronald_70GMC
Wow your gonna have it all man! Jealous over here
Kyle
IG: kyle_ronald
Old 04-17-2020, 08:27 AM   #211
gcburdic
Restoration Virgin!
gcburdic's Avatar
I like it! Did you say yet what you are doing for drivetrain?
Geoff with a G
Old 04-17-2020, 08:58 AM   #212
Graham57a
Graham57a's Avatar
Thanks man, all I lack is finishing
I've been building a 327 for it, all painted and ready to drop in once the crossmember is done. Also keeping an eye out for a 700r to mate up to it
Old 04-17-2020, 09:46 AM   #213
gcburdic
Restoration Virgin!
gcburdic's Avatar
Well, heck...since you're revising the build, why not go ahead and put an LS in it
Geoff with a G
Old 04-17-2020, 10:08 AM   #214
Graham57a
Graham57a's Avatar
Come on man I prefer old school, carbs and factory blocks
Old 04-17-2020, 10:08 PM   #215
preacher anthony
I wish I knew you were changing up. I have a frame w/ front crossmember already pancaked, Porterbuilt control arms, Extreme rear, body drop mounts, custom trailing arms, fully rebuilt rear, 3.73, posi, etc.
preacher anthony is offline   Reply With Quote
Old 04-18-2020, 04:04 AM   #216
darkhorse970
darkhorse970's Avatar
What is that GMC script section off of? I need to do that in a set of big block valve covers.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 04-18-2020, 07:24 AM   #217
Graham57a
Graham57a's Avatar
Early 60s gmc v6 valve covers
Old 04-18-2020, 10:58 AM   #218
darkhorse970
Thanks, I need to find a set of those.
Old 05-26-2020, 06:18 PM   #219
Graham57a
Graham57a's Avatar
Got a delivery of parts the other day for Pearl so progress should be picking up soon.
I did play around with a potential candidate for the dash paint today. I could not find any reproduction dash pads that are the correct dark aqua color so I had to dye my own. I bought a can of vinyl dye from The Parts Place color M04 Dark Aqua. I also used SEM vinyl dye prep before applying any of the actual dye. The first picture is the new dark olive green dash pad that I bought to dye. I think it turned out pretty good, once it all cures I’ll post a pic comparing to a sample from my old dash pad for reference. Last picture is the same dash pad in different lighting
Old 01-30-2022, 07:43 PM   #220
Graham57a
Graham57a's Avatar
Got to work on Pearl a little this afternoon. Between a 9 month old running around and about 6 other trucks it seems like this one keeps getting put on the back burner. Well I’m hoping to change that over the next little bit, we will see how well I can keep at it.
So my current to dos:
I really need to get the front crossmember complete and bolted in for the last time. I worked on metal finishing my welds today and I’m pretty happy with how it turned out. Hopefully gonna take it to work for a blast and powdercoat in the next couple weeks to call it 100% done and bolt to the frame for the last time. All in I’m pretty happy with how the 1 1/2” pancake turned out
Balance of front suspension. I was able to score a set or used porterbuilt tubular uppers and lowers. They are going to make my conversion to bags a million times easier and way cleaner. Mocked them up today with no issues, gonna put them on the list to powdercoat as well.
It looks like I have about 14” clear from “aired out” center of hub to ground. Based on eye balling my orange truck I think I can tuck 22s with really skinny tires or 20s with a fatter tire. That will probably make me go with a 20/22 setup long term but I’m still gonna get a set of steelies for now.
So I got everything mocked up in the front and I’m pretty happy with how it all fits and moves. I think next on my list is to figure out inner fenders so I can verify clearances and what else I have to modify under the hood. I really like the old hills rod and custom style of inners but I don’t think they make them anymore so I may have to do some searching.
After I get my inner fenders figured out I think I’ve got almost everything figured out up front. Gotta get some bags and run some lines but I feel like that will be straight forward (hopefully). Also figure out steering but I think I am gonna go with a rack n pinion to keep it simple.
Lastly I am on the search for rear kits. I’ve been looking at this kit my Chasis Fab https://chassisfabsuspension.com/col...suspension-kit but I’m not totally sold yet. Does anyone have any other opinions to insert here?
Lastly just a few interior pieces that I’ve been working on to show you guys. I’m gonna hold off on any more interior work for a while to avoid getting the cart before the horse. I’m 95% sure I’m gonna be welding and grinding on my firewall again before this is all said and done so I wanna keep that collateral damage to a minimum.
Old 01-30-2022, 07:44 PM   #221
Graham57a
Graham57a's Avatar
Last few pics:
Old 01-30-2022, 09:18 PM   #222
Grip
Grip's Avatar
Nice score on the Porterbuilt arms. Are they one inch sorter and one inch forward?
Eric
68 Anniversary Gold C-20 LWB to C-10 SWB build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=637492
It's hard to explain puns to kleptomaniacs because they always take things literally.
Grip is offline   Reply With Quote
Old 01-30-2022, 11:42 PM   #223
Graham57a
Graham57a's Avatar
Yes they are
Old 01-31-2022, 03:31 AM   #224
SCHRUMGMC
SCHRUMGMC's Avatar
Beautiful truck, and excellent progress on the old gmc
Enjoying the photos of it all
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 02-01-2022, 01:27 AM   #225
68bowtie
68bowtie's Avatar
Looking great!
