Old 04-17-2020, 02:47 AM   #1
Ron90
Drive shaft
I have a 1963 GMC half ton long bed that I recently lowerd it currently has a one piece drive shaft and it is rubbing I want to change it to a two piece drive shaft what truck can I get this from does it have to bee a 60-66 truck or can it be a different year my truck is set up with a big block and a 400 transmission any info on the subject would be much appreciated
Ron90 is offline   Reply With Quote
Old 04-17-2020, 10:47 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Drive shaft
Talk to the good folks at JE Reel Driveline Service.
Address: 448 S Reservoir St, Pomona, CA 91766
Phone: (909) 629-9002
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-17-2020, 01:07 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Drive shaft
67-72 has the same wheelbase as ours.
Second generation (1967–1972)
Wheelbase:
115 in (2,921 mm) (short box)
127 in (3,226 mm) (long box)
133 in (3,378 mm) (Longhorn)
73-87( through 91 for subs)
Third generation (1973–1991)
Wheelbase:
117.5 in (2,984 mm)
131.5 in (3,340 mm)
164.5 in (4,178 mm)
First generation (1960–1966)
Wheelbase:
115 in (2,921 mm) (short box: ½-ton models)
127 in (3,226 mm) (long box: ½-ton & ¾-ton models)
133 in (3,378 mm) (1-ton models)
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 04-17-2020, 01:11 PM   #4
LostMy65
LostMy65's Avatar
Re: Drive shaft
Now, the variables will be your transmission length and the rearend you have.
Old 04-17-2020, 01:25 PM   #5
LostMy65
LostMy65's Avatar
Re: Drive shaft
More copy and paste:
(All found using Google)
The overall length of the TH-400 is 38 inches, while the overall length of the TH-350 is 33 5/8 inches, if both use the longest tail shafts available. The TH-400's body is 25 inches and the TH-350's body is 21 5/8 inches long. The tail shafts for the TH-350 are available in 6-, 9- or 12-inch lengths and the tail shafts for the TH-400 are available in 4-,9- or 13-inch lengths.
Old 04-17-2020, 09:18 PM   #6
Captainfab
60-66 Nut
Re: Drive shaft
You are going to have to have one either custom made or at least shorten one to the correct length. It is impossible to find one that is going to be the exact fit for your specific engine and trans combo. There are just too many variables. With that said, you will want a HD driveshaft. If you need the mount for the HD carrier bearing, I make those.
http://67-72chevytrucks.com/vboard/s...d.php?t=620312
Old 04-18-2020, 05:11 AM   #7
Ron90
Re: Drive shaft
Ok so I should be able to make a 67-72 drive shaft work possibly shorten it to the length I need. What is an HD drive shaft? Is the HD carrier bearing mount something I can bolt on or would I have to weld it in? I was also wondering if it would be possible to just cut or ream out the top portion of the cross member to give the drive shaft clearance???
Old 04-18-2020, 10:52 AM   #8
LostMy65
LostMy65's Avatar
Re: Drive shaft
Do you have a picture of your frame where the trailing arms connect to the crossmember?
Old 04-18-2020, 11:06 AM   #9
LostMy65
LostMy65's Avatar
Re: Drive shaft
I found a pic in captains thread he linked for you.:
Old 04-20-2020, 01:14 AM   #10
Ron90
Re: Drive shaft
The truck is a GMC and has leaf springs in the real
Old 05-08-2020, 05:15 PM   #11
lowslow64
lowslow64's Avatar
Re: Drive shaft
Leave the one piece shaft in, most get rid of the two piece due to the weak carrier bearings. Just replace the cross member to a dropped one and you will be in good shape. I had a long bed and shortened it to a stepside. I got rid of the two piece because they are junk. Ordered a dropped crossmember from CPP and had a one piece shaft made with a slip. I have never had a problem in over 5 years of doing that. Trust me you will never be happy with a two piece.
lowslow64 is offline   Reply With Quote
