Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Paint and Bodywork
Old 04-17-2020, 05:01 PM   #8
Gregski
Gregski's Avatar
Re: Where you all get your weld through primer these days?
Originally Posted by LockDoc View Post
Copied from the H.A.M.B.
... It WILL fail and peel if used on surfaces other than the inside flanges in a pinch weld...
That said, I use it in both modern collision and restoration, but only where its "pinched" between two pieces of steel...
LockDoc
Would you consider welding on angle iron that runs the length of a 1954 truck bed on either side at the bottom just above the wood planks a pinch weld? I plan on drilling holes in my angle iron every 6 inches then mimicking spot welds (aka rosettes) in those holes to the bed sides using my MIG. I plan on using weld through primer on the back of each angle iron and along that line on either bed side.
Gregski is offline
