Old 04-18-2020, 09:52 AM   #1
RJC
Re: Spring spacers
I replaced upper and lower control arm bushings and bushings shafts., used all moog stuff and yes i did install lower shaft to align with knob on chassis. Replace upper and lower ball joints, tie rod ends etc.
The springs are sitting in pockets top and bottom. I do see that the spring is not centered going up towards the top pocket.. almost touching chassis towards the front. The passenger side sits centered and perfect.
I cannot find and indication that frame is bent, or hit anywhere hard.
Not sure if I did anything wrong when rebuilding from end to mess up spring alignment
Any help greatly appreciated
RJC is offline   Reply With Quote
Old 04-18-2020, 03:50 PM   #2
PepperTreeGarage
PepperTreeGarage's Avatar
Re: Spring spacers
Only thing I can think of is did you replace Cab and Core Support mounts?
PepperTreeGarage is offline   Reply With Quote
