Old 04-18-2020, 12:42 PM   #1
LT102
LT102's Avatar
Protecting Radiator Support from Battery Corrosion
Pulled the battery and tray from my 71' and was surprised to see all the corrosion on the radiator support caused by the battery. Never seen any liquid come from the battery so I'm assuming it's gasses from the battery. How can I protect the support and other parts in the area from this corrosion? Do I need to go to a sealed type battery? Thanks in advance for your help.
LT102 is offline   Reply With Quote
Old 04-18-2020, 01:00 PM   #2
toolboxchev
Re: Protecting Radiator Support from Battery Corrosion
Yes a sealed battery will help, yet I believe they all have some type of vent.
Biggest part of the problem I can see is the old style separate voltage regulator.
I had one go into an overcharging situation a year ago. It was putting out over 19 volts to my electrical system. It did make my Optima Red Top battery spit some juice out of the vent. Got all over my new radiator.
With the old style system every time you start your vehicle those old regulator will push more than 16 amps to get the battery back up to snuff. I believe that would be a main cause, or where I am going to begin looking.
toolboxchev is offline   Reply With Quote
Old 04-18-2020, 06:01 PM   #3
HO455
HO455's Avatar
Periodically rinsing the area with a water and baking soda mixture will help by neutralizing the acids the battery vents out. Then you can rinse that off with clean water after 5 or 10 minutes.
RIP Bob Parks.
Old 04-18-2020, 06:53 PM   #4
68Gold/white
X2!!!
Batteries put off acidic vapors. My knowledge of sealed batteries is zero...
I clean up the battery tray on my 77 TA every few years, repaint it. I try to buy the best batteries, not sure what that would be these days. I used to sell AC Delco batteries, they were awesome.
Speaking of voltage regulators. THe old external regulator on my 67 Bel Air was sticking for a while, man I had beech'n headlights for a while. It also shortened the life of my awesome AC Delco battery...
68Gold/white is offline   Reply With Quote
Old 04-18-2020, 07:45 PM   #5
Clatterville trolley
Clatterville trolley's Avatar
Do those battery tray mats really do any good - have seen them advertised but never tried one.
PayPal 1windyridgeboy@gmail.com
Clatterville trolley is offline   Reply With Quote
Old 04-18-2020, 11:39 PM   #6
SRU1436
I’m curious too, I was looking at them the other day. I hope someone will chime in on if they are good or not.
SRU1436 is offline   Reply With Quote
Old 04-18-2020, 11:57 PM   #7
I've had good luck keeping the core support free from battery crud by removing the battery every so often to inspect the tray, clean, treat, and paint when needed. If I see a mess below (rare), I rinse or scrub before neutralizing/coating
Old 04-19-2020, 06:41 AM   #8
Boog
laying low
Boog's Avatar
I wonder if coating the battery tray and all area around it with something like POR 15 would prevent corrosion from battery acid?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-19-2020, 06:48 AM   #9
'68OrangeSunshine
'68OrangeSunshine's Avatar
They work OK, but they're not a magic cure for negligence.
Periodic hosing down and baking soda rinses are still required. I have to re-paint my battery tray every few years.
Old 04-19-2020, 12:34 PM   #10
Thanks for the replies - wasn't trying to high-jack thread - just seemed to go along with what was being said. Jay
Old 04-19-2020, 12:38 PM   #11
HO455
HO455's Avatar
I haven't tried POR 15, but I can tell you that professionally installed spray on bed liner will not work.
RIP Bob Parks.
Old 04-20-2020, 09:03 AM   #12
clay68c10
clay68c10's Avatar
Using an AGM type battery will help. They (usually) only leak if you have a charging system problem.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 04-20-2020, 10:41 AM   #13
71gmcC15
71gmcC15's Avatar
My core support has a big hole in it so I dont worried about it.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
