04-19-2020, 10:57 AM | #1 |
Moderator
Re: Aftermarket fuel gauge OHMS
I believe all of the T800 trucks instrument panels are digital using stepper motors to drive the needles... unlike the older rigs with air core analog gauges.
Most if not all of the gauges in the instrument cluster get their information from the PCM over the Class II serial link. The 2nd design T800 that started in 2003 had problems with the stepper motors in the gauges failing and cracking solder joints on the SMT resistors. There are bunches of videos on repairing them. I'm not sure about the 1st design 99-02 trucks. You can do lamp and gauge sweep tests using a Tech 2 to figure out whether the gauges and lamps are working then go from there. You can leave it plugged in. I would. Why do more work than you need to. Torque Pro and a decent quality Bluetooth CAN/OBD II adapter will let you use an Android tablet or phone to display custom gauges. You need to enable the extra GM PIDs. You can get PCM Voltage, Eng Temp, Eng Oil Pressure, Fuel Level, Trans Temp, Tach, Speedometer, and Odometer along with several other pieces of data displayed on a tablet or large phone. All of that data comes out over the J1962 OBD II datalink.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-19-2020 at 03:12 PM. |
