Old 06-22-2004, 01:14 AM   #1
69K10 Tank
Exclamation Need tanny help ASAP
Ok, so on my way home tonight my tranny locked into 4th gear. I have an sm465. I was comming up by a friends house and pushed the clutch in and reved it in 4th and let the clutch out and continued home, so when I pulled onto my street about a block away I couldn't shift out of 4th. The clutch still works, it just wont shift. Please tell me what is wrong. Thanks guys. Kevin
Cry havoc and let slip the dogs of war
69 K-10, 350, sm465, T221, 33" BFG A/T, drums all around (soon to be discs)
69K10 Tank is offline   Reply With Quote
Old 06-22-2004, 07:02 AM   #2
JimKshortstep4x4
Smile
My guess would be that the syncronizer is worn and is jammed. Could be serious.
Jim
Old 06-22-2004, 10:32 AM   #3
TRUCKPOOR
Shift rods in top of tranny are a little worn. Remove the shift lever and realign the rods by pushing them in their respective place with the end of a screw driver and reinstall shift lever. Should take 15 to 20 min your first time, 5 to 7 each time after that. Mine will occasionally stick in second, shift handle is in nuetral and won't shift to another gear until rods are aligned. Good Luck,
TRUCKPOOR is offline   Reply With Quote
Old 06-22-2004, 10:42 AM   #4
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
I have a tranny just like that and it will bolt right in. Im in idaho and would ship if you want a good one. Ill guarantee this one will work good. Im asking a 100 for it. JT
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 06-22-2004, 11:19 AM   #5
Russell
Professional Grade
Russell's Avatar
If you were a bit closer to Alberta, I'd give you one that has 23 000 miles on it for free, just needs a throwout bearing and shift arm...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-22-2004, 11:45 AM   #6
69K10 Tank
Thanks guys, I'll see if I can realign the rods this afternoon when I get home from work. Stealth2002, if something is really seriously wrong, you might be hearing from me. Kevin
Old 06-22-2004, 12:17 PM   #7
jostrans68
Jostrans68
jostrans68's Avatar
I have a good tranny if you need it its yours come get it before I junk it....
FREEEBIE FREEBIE
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 06-23-2004, 12:09 AM   #8
69K10 Tank
Thanks for all the help guys. I pulled the seat and tranny tube out this afternoon so i could get to the tranny. Well I pulled the bolts on the top cover and started to pull it off...but it wouldnt come off. And then it shifted again, I didn't do anything but whatever was outta whack it fixed itself. Thanks again though guys, this place rocks. Jostrans68, is the tranny a 2wd or 4wd?
