Old 04-20-2020, 12:01 AM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
A/C Question
When I bought my truck 5 years ago this valve lever thing was on it and I guess you open it for colder temp driving and close it for summer driving. Now where its attached to on the A/C side it looks like some kind of valve underneath and I'm figuring that is shot and that's why the lever thing is there, as a cheap fix. I'm getting where I want to get that out of there and replace the red hose with a black one so what is the thing called on the A/C side of the hose and are they available.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 04-20-2020, 12:53 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: A/C Question
A couple years ago I was dealing with an A/C problem, and the cooled air was getting warmed up before coming out of the vents. I place a ball valve in the heater hose, similar to what you have pictured in the red hose. (Turned out that wasn't my problem though -- I was missing the flapper valve (?) in the pass. side of the cowl). Anyway you're right, closing that valve prevents hot coolant from entering the heater core.
The other valve is called a water control valve or heater control valve. They are available at many places. Here's one: https://www.classicindustries.com/pr...ts/ap4610.html
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 04-20-2020, 12:59 AM   #3
randy500
Re: A/C Question
Thats a ball valve that is auxiliary to the factory water valve down stream in your picture.
The factory one probably is leaking.
Ac delco 15-51293 is what you need to replace yours. The valve closes when ac is in recirc mode.
randy500 is offline   Reply With Quote
Old 04-20-2020, 01:51 AM   #4
Already Gone
Re: A/C Question
So if I replace the water valve can I do away with the ball valve thing ?
Old 04-20-2020, 02:04 AM   #5
randy500
Re: A/C Question
Yes, someone added the ball valve to ensure full shutoff. Just take it off.
Old 04-20-2020, 02:10 AM   #6
Already Gone
Re: A/C Question
Thank you.. RockAuto has the AC Delco one you mentioned. I will get it ordered up this week along with some other items I've been wanting to get.
Old 04-20-2020, 08:38 AM   #7
kaycee
kaycee's Avatar
Re: A/C Question
Yeah hes right I put one in mine and close it during summer it knocks the heat down going to cab.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is online now   Reply With Quote
Old 04-20-2020, 09:06 AM   #8
Andy4639
Old member
Andy4639's Avatar
Talking Re: A/C Question
If you are wanting a 100% AC to work good then I would leave it. That ensures the hot water doesn't come into the cab while the AC is on. Most people put it in the other line though. If the vacuum operated valve leaks hot water by then your AC will never get as cold as it should inside the cab. Putting it in the other line makes sure it doesn't circulate at all through the heater core.
If you do decide to take it out a simple test is to feel the lower part of the interior heater box to see if it is warm when the AC is on and the truck is sitting still. If it is some what warm then you have water leaking by the vacuum valve and you will not get the cab as cool as it could be.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-20-2020, 09:16 AM   #9
Sheepdip
Sheepdip's Avatar
Re: A/C Question
It could be that your vacuum hose(s) to operate the factory valve have become brittle, cracked and are leaking and a possibility as to why they added the ball valve was installed. If the new valve does not solve the problem I'd give the vacuum hoses the eagle eye.
Sheepdip is offline   Reply With Quote
Old 04-20-2020, 05:29 PM   #10
Davidf
Re: A/C Question
Or to test: when the heat is off, the hose on one side (downstream side) of the factory valve should be cool.
Davidf is offline   Reply With Quote
Old 04-20-2020, 11:43 PM   #11
Already Gone
Re: A/C Question
I'm replacing my heater core pretty much as soon as truck is out of storage and plan to check everything in heater box etc. at same time.
Old 04-20-2020, 11:47 PM   #12
randy500
Re: A/C Question
I can almost guarantee the vac hoses are bad, i had some nice looking sets and tried to use them, they all cracked at the nipple after a couple of months.
Definately check that.
OER makes a copper heater core, it isnt cheap at $109 or so. I installed an aluminum one last year and it was a real chore, the core is too thin and you have to make a spacer for it to fit. Buy the copper one it looks like factory.
Old 04-20-2020, 11:54 PM   #13
Andy4639
Old member
Andy4639's Avatar
I install one in every truck I own. It's a good way to get the cab cooler here in the south.
Just for some more info. Even if the heater is off the hot water can come into the heater core.
My Ramp truck is only heat and it would get so hot you couldn't stand it. I put the shut off in the line and it's nice during the summer now.
Old 04-22-2020, 02:38 AM   #14
Already Gone
Re: A/C Question
Bought the one in the link last fall and will be installing it. Found out about it on here a member bought one from them. I had it checked out and the welds etc. are excellent quality.
https://www.npdlink.com/product/core...1972&year=1972
