Old 04-23-2020, 03:52 PM   #1
msg
1966 C10 Fleetside Body plug list?
I am putting together an order and I think there are more than 4 body plugs that I need. So far I have the rocker panel plugs and the lower door plugs that are on the side of the door below the door latch. I must be missing a few cause I went through a box of "extra" parts I didnt label as I disassembled and I cant recall where this one came from. Its around 2 inches wide. Is there a list someone may have to show what I should order just in case Im missing a crucial one?
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 04-23-2020, 04:15 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 1966 C10 Fleetside Body plug list?
Is it Oval? If it is it goes where the clutch hole would be. So it probably came off an automatic truck? Just brain storming here.
Old 04-23-2020, 04:16 PM   #3
msg
Mine is an automatic, yes. I think the plug got distorted. Guessing it should be round. Ill look at the original pics I have and see if its from that area. Are there any other plugs you can think of I would need to complete this truck?
Old 04-23-2020, 04:22 PM   #4
The Rocknrod
Moderator
No, they dont get distorted there is an oval hole in the firewall near the throttle. I'll see if I can find the pics. Here you go - Clutch rod:
Old 04-23-2020, 04:58 PM   #5
msg
Sweet! Thanks man, I may have to reuse what I have. I didnt see it in the Truck Shop catalogue. The boot is there but no plug.
Old 04-23-2020, 06:04 PM   #6
msg
Correction:
I called in and they have one that looks like what I have item # 67-039021 pg 40.
It was just enough to add to the order to get the free shipping, so I went with it.
One thing they didnt have was this other thing that came up when I went looking through my tear down pics.
From what I can tell there is supposed to be some kind of round rubber part on the inner fender.
I found at Classic this and think its what I need.
https://www.classicparts.com/1960-66...ctinfo/37-852/
Old 04-24-2020, 07:28 PM   #7
kens65fb
Do you have a pic of the passenger side firewall ??
kens65fb is offline   Reply With Quote
Old 04-24-2020, 07:35 PM   #8
The Rocknrod
Moderator
