Old 06-07-2004, 11:50 AM   #1
sider68
sider68's Avatar
90 Gauge Cluster
My odometer stopped working and I,m tol it is due to a fault in the gauge cluster.Can this be repaired?Do other years fit...mine is a 1990?Should I go to the wreckers and just replace it.Please advise.
sider68 is offline   Reply With Quote
Old 06-09-2004, 01:06 PM   #2
AnniesSS
A friend of mine has his repaired and it was quite pricey. You're probably better off finding another one in a junk yard and having the odometer reset
Annie
1990 Chevrolet 454SS
1989 Chevrolet Suburban 2500 Silverado
AnniesSS is offline   Reply With Quote
Old 06-11-2004, 11:48 PM   #3
sizanjdf
ive got an 88 and mine wasnt working either....found a wrecked truck and gave 75 bucks for the whole cluster and just popped it in.
sizanjdf is offline   Reply With Quote
Old 06-21-2004, 06:38 PM   #4
CanadianFolk
CanadianFolk's Avatar
cluster will pop right in but make shure drivetrain and tires are the same or yer speed will be off by 10-20 mph...these truck have diffrent setups depending on drivetrain if l remeber correctly
CanadianFolk is offline   Reply With Quote
Old 06-21-2004, 07:14 PM   #5
1972C10
1972C10's Avatar
the speedo should be the same regardless of tire size and gears because the speedo gears in the trans dicatate that the speedometer is just rated at a certain ohm and that varys for speed
1972C10 is offline   Reply With Quote
Old 06-23-2004, 02:05 PM   #6
99-2door
99-2door's Avatar
That's right the VSS it actually what is different on these older trucks, not the cluster.
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80
2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc.
2003 Tahoe Z71 Silverado front clip
99-2door is offline   Reply With Quote
