Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 06-23-2004, 12:14 PM   #1
n737nc
Stupid question that will not bennefit me in any way...
Why do they call it a torque WRENCH ?
n737nc is offline   Reply With Quote
Old 06-23-2004, 12:59 PM   #2
71swb4x4
71swb4x4's Avatar
It's a wrench
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-23-2004, 01:16 PM   #3
n737nc
Looks like a ratchet.
Old 06-23-2004, 01:50 PM   #4
Putter
More Cowbell....
Putter's Avatar
...but it does NOT ratchet.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 06-23-2004, 01:51 PM   #5
68C15
blood type; Retumbo
68C15's Avatar
a ratchet is actually called a ratcheting wrench.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-23-2004, 01:52 PM   #6
68C15
blood type; Retumbo
68C15's Avatar
hey Putter, all of mine ratchet. the original ones were just a bar with non bending pointer.
Old 06-23-2004, 02:23 PM   #7
TsgtE662
2A674 Tank Rat
TsgtE662's Avatar
Some ratchet and some don't. Some are in inch/lbs, ft/lbs and Newtons.
I have a 2000 ft/lb Torque wrench here at work with 4 pipe extensions that has a dial gage, along with a few in smaller increment ratings.
'92 GMC Sierra, Sportside, 2wd, 350, Black
'92 Chevy Silverado Extended Cab 4 x 4, Blue
USAFR = 2A674 = Aircraft Fuel Systems Maintenance
i.e. Tank Rat
TsgtE662 is offline   Reply With Quote
Old 06-23-2004, 02:37 PM   #8
walker
walker's Avatar
I believe the original Snap On wrenches with the snapon/off adapters(sockets) were called socket wrenches, and they did not ratchet. They then came out with ratcheting socket wrenches, or ratches. I suppose they could be called torque ratchets, or torque socket wrenches, or even ratchetingtorquesocketwrenches, but that last one is a little long. I think I'll stick with torque wrenches. think I have that same 2000 pound torque wrench and cheaters. I have only used to 1500 pounds though. Now I have a torque multiplier. It is essentialy a 6:1 reduction gear transmission, with of course a socket head adaptor It also ratchets. Would that be a ratchetingreductiongeartorquemultiplyingtorquesocketwrench?????
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 06-23-2004, 02:38 PM   #9
walker
walker's Avatar
BTW the answer will benifit you in making you a more well educated person
Andy,Phx AZ
"23 C-Cab-sold
'70 MG B.-sold
Old 06-23-2004, 04:34 PM   #10
Stingray42
Woot.
Stingray42's Avatar
what the hell do you torque to 1500-2000 ft lbs?!? lol
Clarkson
96 Chevy RCLB 4.3 2WD
Stingray42 is offline   Reply With Quote
Old 06-23-2004, 06:57 PM   #11
'70_402
'70_402's Avatar
the only time i used more than one pipe extention i ended up with a busted lip!!
'70_402 is offline   Reply With Quote
Old 06-23-2004, 07:29 PM   #12
cheatham
I need a brake!
cheatham's Avatar
I've been calling rachets socket wrenches as long as I can remember. Right or not, I'm sure I picked it up from my dad.
JP
MEMBER OF THE DISCS UP FRONT CLUB
1971 Chevy C10
cheatham is offline   Reply With Quote
Old 06-23-2004, 09:03 PM   #13
Quagmire
A splendid one to behold
Quagmire's Avatar
ditto, i'm curious also...
67 swb
02 wrx
Quagmire is offline   Reply With Quote
Old 06-23-2004, 09:33 PM   #14
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Used to use hydraulic torque wrenches to torque the drive-carrige bolts on large excavators, torqued them to about 2-3000 ft-lbs. Allot esier than when in the corps using a few cheater pipes to tighten sprocket bolts on a tank.
NeCrOmAnCeR is offline   Reply With Quote
Old 06-24-2004, 11:47 AM   #15
TsgtE662
2A674 Tank Rat
TsgtE662's Avatar
We torque aircraft flap attach hinge stud bolts to 1400 ft. lbs. onto the back part of the wings. Certain ones require this, some of the others require lesser torque amounts.
The Flap Hinges bolt onto these studs and the Flaps attatch to the hinges, basically.
It takes 4 -5 of us to do it.
i.e. Tank Rat
Old 06-24-2004, 12:17 PM   #16
Stingray42
Woot.
Stingray42's Avatar
wow. thats awesome
Clarkson
Old 06-24-2004, 12:32 PM   #17
COBALT
COBALT's Avatar
wrench ( P ) Pronunciation Key (rnch)
n.
1. A sudden sharp, forcible twist or turn.
2. An injury produced by twisting or straining.
3. A sudden tug at one's emotions; a surge of compassion, sorrow, or anguish.
4. A break or parting that causes emotional distress.
5. The pain so associated: felt a wrench when he was parted from his children.
6. A distortion in the original form or meaning of something written or spoken; twisted interpretation.
7. Any of various hand or power tools, often having fixed or adjustable jaws, used for gripping, turning, or twisting objects such as nuts, bolts, or pipes.
In other words wrench != rachet. The word "wrench" applies to all hand tools for adjusting torque. The word "rachet" only applies to hand tools that adjust torque that actually rachet.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-24-2004, 01:02 PM   #18
TsgtE662
2A674 Tank Rat
TsgtE662's Avatar
Stingray42 - It would less awesome and much more appreciative if certain hotdog pilots would not over -g the aircraft and dern near rip a flap off! lol
I work the fuel systems and these studs go into the tanks in which we have to seal them. One aircraft in particular was fine before, but came back with over a dozen fuel leaks! Um, that was alot of fun. Not sure if that pilot was a Redneck or not, but they did land safely.
i.e. Tank Rat
