#26 | |
Collector of Projects
Re: 2wd to 4wd.....just curious
For the rear, I went with a later model 2004 GMC 2500 with disc brakes and a drum in hat emergency brake. Nice to have 4 wheel disc brakes... |
#27 |
Thanks for the info guys....lots to consider. At the moment, its a 3/4 ton C20 with a built 6.0L LS and STG II 4L65E. The rear is the factory Dana 60 and I've already converted to 4 wheels disc brakes....although I do not yet have a parking brake solution.
1972 C20 Suburban 1964 Corvette Coupe 1997 Lexus LX450 |
#28 |
Was it a factory big block truck? Interesting that it is Dana 60 as most small block coil trucks were HO52.
One of the reason I like sticking with the drums. I have an '86 Sub rear in my Jimmy, 8 lug semi-float with the 13" drums. Parking brake works GREAT!
#29 |
Yes, it was a factory C20 with the 402 big block and trailing arms with coil springs in the rear. It does have the "helper" leaf springs for towing.
#30 |
![]() Join Date: Feb 2016
For the quad curious.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#31 |
nice, thanks! Decisions, decisions, decisions....
#32 |
How deep are your pockets?
Custom modular chassis for 67-72 4x4 trucks...K5 Blazer, K10/K20 SWB or LWB ... 4 linked or IFS... SBC BBC LSX 6BT check them out at www.patriotchassis.com First build was an IFS 3/4 ton LSx powere Blazer with a 4 link in the rear that's AWD like a late model Yukon Denali |
#33 | |
72 GMC 2500 Camper Special, 72 Chevy K20(sold) 83 Chevy K20,2004 Chevy SWB (sold) 71 Chevy K5 (sold) miss this one the most 71 Chevy K5 (sold),95 GMC 2500 (sold) 77 Chevy SWB (sold)78 Chevy SWB (sold) 79 Chevy Big 10 (sold)77 Chevy Big 10 (sold) |
#34 | |
DANGER! DANGER! Thanks for the link! In all seriousness, this is an option I'd like to explore...looks like their prices are SIGNIFICANTLY more reasonable than the Roadster Shop chassis I posted in another thread a few weeks back.
1972 C20 Suburban 1964 Corvette Coupe 1997 Lexus LX450 Last edited by FLYNAVY30; 01-29-2020 at 08:04 PM. |
#35 |
I’m converting a pristine rust free 2WD 1968 to 4x4 using a 1972 4x4 frame - keeping the title from the 72 in case there issues down the road. It’s about a 2 day job to remove entire body. I’m also adding a 12 valve Cummins and Dana 60 front Dana 70 rear to the build. Hoping to be complete this summer....
#36 |
So going back to the topic of transfer case......
My Gearstar stg 2 4L65E is plenty strong for my purposes.... would it make more sense to change the output shaft in order to accommodate a married np205, or leave it as she sits and include a second crossmemeber to mount a divorced t-case?
#37 | |
info on the NP205 … https://www.offroaddesign.com/tech/o...al-information front axle install/swap... https://diy4x.com/product.php?productid=17716 |
#38 |
Thanks for the link, good info!
#39 |
Going further down the rabbit hole...
If you use the DIY4x kit to fit the 52" leaf spring in the front, how do you determine what rate coil to use in the rear in order to provide a decent ride quality? Obviously you can get different spring heights to adjust the rear ride height to match the front, but I would also want to ensure good ride quality and handling (for a truck).
#40 | |
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
#41 | |
https://www.carid.com/moog/problem-s...l#applications |
#42 |
Here is a little more information on th e DIY4X4 front spring kit.
http://www.67-72chevytrucks.com/vboa...d.php?t=805048
#43 | |
good read, thanks!
#44 |
K model Burban listed here. It's a ways away from you, but.....
https://phoenix.craigslist.org/evl/p...102423305.html
#45 |
interesting cab conversion on the Burban chassis. Unfortunately, its going to be at least another year before I can start shopping for a chassis as I just got extended in my current orders....which means I'm stuck in my single car garage/condo for the time being.
#46 |
Sorry to hear of the delay. HOA's are bad enough let alone in a Navy town. Hard to even change a flat tire without hassle.
#47 | |
Fortunately our place in Texas has a 1000 sq ft garage and no HOA!!
#48 |
I spent close to five years in Norfolk. I know the pain. There used to be a pretty good shop on base I would rent to do stuff (like rebuild the motor in my GTO). But they tended to frown on longer term projects. There even was a body shop with a paint booth. I painted the goat twice (there was a learning curve).
I suppose these days all that is gone.
#49 | |
Oh yea, there's a shop on base still, but its only useful for changing oil, or projects you know will be done in a couple hours.
#50 | |
![]() Join Date: Nov 2013
I have a '71Blazer frame to compare I think a coil front and rear would be a dandy combination.....I'm no longer into hard core off roading...but this would be cool 4WD driver...?
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
