1971 c10 steering column help!!!
Had this column from my 71 three on the tree tore it apart to put new turn signal and horn parts as well as remove column shifter handle and nub put all back together and now the steering wheel pulls right out with shaft as seen in picture is there something im missing or is the intermediate shaft hold that ?
Re: 1971 c10 steering column help!!!
There is a spring & clamp that goes on the bottom of the shaft. Often the lower brg. gets stuck to the shaft & locks the shaft from coming up. The spring comes in a kit with the lower brg. & I think the clamp does too. Its been a long time since I did one but i'm pretty sure the clamp is included in the kit.
George |
![]() Join Date: Nov 2018
There should also be a big thick 1/4" +/- washer that goes at the bottom of the column
Anyone have any idea where i could buy a original style intermediate shaft lmc doesnt show it i had one i sold on my parts frame kick my self for not tearing more parts off it
#5 | |
I took a zip cut removed the most of the nub buffed and then sanded it cut a small piece of steel to fill hole and since it is pot metal i used jb weld to glue to two together i also put a fat sharpie market behind the column piece and filler metal to hold while i jb welded it also jb weld is sand able so i did two thin coat and got it smooth
#7 | |
#10 | |
Posted via Mobile Device |
Thanks again for posting your process. Gave me the "nerve" to remove the nub, came out better than expected!
Tags |
steering column help |
