Old 04-26-2020, 10:40 AM   #2
mick53
Re: Speedhuts
I have Dakota Digital HDX gauges with GPS speedo. It updates 10 times per second and has memory for when signal is lost and self calibrates. It also runs cruise control. The HDX gauges record 1/8 and 1/4 mile times and 0-60 times. also top speed and final speed. They have 16 different gauges you can add modules for without adding more gauges. I have a Frankland quick change rear end with 128 gear ratios available and Tremec TKO 600 trans so That's one of the reasons I chose it. IT has an internal antenna but I'm guessing external is better. It is compatible with other gauges.
https://www.dakotadigital.com/index....rod/prd837.htm
mick53 is offline   Reply With Quote
