Old 04-27-2020, 08:20 AM   #10
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Pros cons on complete AC systems
If you have all the factory AC stuff go back with it. All you need is a few parts to go to 134-A.
If you do the factory AC right and have it charged up right you can have 134-A in it and it will work just fine. But you will need to swap some parts out. Here is my old 305 motor with stock looking AC with modern guts. It blows 38* air on low. It's running 134-A. Good air flow through the radiator and good fans make a big difference in AC performance.
Making sure the hot water is closed when AC is running makes a big difference in cab temperatures.
Keeping the air flow on the condenser, there are many small things that help get the cab cool.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
air conditioning
