Old 04-26-2020, 04:09 PM   #1
hubdawg
Transfer case ID help
Swapping transfer cases and noticed the difference between the two. The one on the right came from my running donor ls/th350 combo. Don't know what the additional attachment on it is for. The one on the left came from the parts vehicle and I'm pretty sure it's a 205. Should I go with the running donor and the unknown transfer or swap
hubdawg is offline   Reply With Quote
Old 04-26-2020, 04:16 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Transfer case ID help
My guess is aa PTO unit, 205, what does the front of it look like, maybe a drive shaft knuckle?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-26-2020, 04:36 PM   #3
hubdawg
Having problems with photos but it does have a shaft with a keyway slot so I'm thinking PTO also. Any value to this or just extra weight if not used
Old 04-27-2020, 01:53 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Looks like PTO unit. See thread here: http://67-72chevytrucks.com/vboard/s...d.php?t=280068
Old 04-27-2020, 02:12 PM   #5
jaros44sr
jaros44sr's Avatar
If you want to get rid of it I may be interested, just another cool add on. lmk
SAFETY FIRST
AS usual, off topic
Jim
Old 04-27-2020, 02:49 PM   #6
MJN
MJN's Avatar
Both cases are NP205's. The one on the right has a PTO on it, chances are it was used to run a winch or hydraulic pump. They're more common to have mounted to a manual transmission but since a TH350 doesn't have a provision for a PTO they used the T-case.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 04-28-2020, 11:14 AM   #7
hubdawg
Can I just remove it and plate it off or do I have to do something else
Old 04-28-2020, 11:16 AM   #8
MJN
MJN's Avatar
Just take it off and put a cover back on it. Good chance to take a peek at the gears and other internals too.
'17 GMC Yukon XL
VCCA member #58596
Old 04-29-2020, 04:20 PM   #9
kwmech
Yup, take it off along with the studs and use the plate from the other case to plug the hole. Looks like you may have it sold already...if not I'll buy it from you.
Old 04-29-2020, 05:43 PM   #10
hubdawg
Thanks for the input guys I think I'll put in the non pto unit in and probably sell the other one. Going to be a couple of weeks till I do it and I'll contact the people who showed interest in order of contact. Thanks again love the great help out there!
