![]() Join Date: Mar 2011
Re: PO has me PO'd
looks great.....
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
![]() Join Date: May 2006
Re: PO has me PO'd
Thanks bud, just looking at your home chrome, nice work, may look into doing that at home, maybe buy my wife a new range and use her old one in the basement
How are you holding up over there in Jersey
#3 | |
Re: PO has me PO'd
My wife and childeren so far so good are fine My daughter in law is a RNNP she works in the infectious disease dept that was her choice way before all this. We are worried to say the least. We are about 20 miles west of the epicenters county’s. and hunkered down. My wifes Mom passed yesterday from the virus she was in a nursing home 87 its more sad cause we couldn’t see her for the last almost 8 weeks she is at peace now. I hope you and your family are ok and we all get through this. Jess
#4 | |
Re: PO has me PO'd
we also have my mother-in-law in a nursing home and are worried, since we can't visit glad to hear the rest of your family is doing well, but sad times for a lot of us
Re: PO has me PO'd
exhaust on the cheap
went on NAPA's catalog, came up with an assortment of hangers and clamps, had to modify some of the hangers. Then had to drill a rivet, as it was in the exact place where I wanted to mount the hanger, my least favorite thing to do, after about 2 hours of stepping the drill size up and 2 batteries, worked out. ![]() ![]() took my old 1 1/2" pipes to a shop and used them as a template, nothing fancy, no mandrel bend turn downs had to be adapted for now, later will have the exhaust bent over axle
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-07-2020 at 10:28 AM. |
Re: PO has me PO'd
![]() moved the truck to the back yard so i could test some systems out, problems with the temp. gauge, fixed by part from NAPA G1852, sent off to a1971 blazer, and he turned it down to 3/8" ,quickly. now the gauge reads as it should(thanks to the guys on the electrical forum) also bought a repair kit from AA #34620 next was the hydro boost, pedal was pulsing, air in the system, just kept bleeding system, by turning lock to lock, and drilled a small vent hole in cap. takes a while to get all the micro bubbles out now trans doesn't want to shift into gear, maybe an adjustment, also my pan gasket leaks, waiting on a gasket from lube locker
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 06-19-2020 at 07:15 AM. |
