![]() Join Date: Mar 2019
67 No factory radio option?
Hello everyone-
just picked this 67 c10 and i see that there is not antenna on the cowl. There also is no radio wiring behind the dash. Was there an factory no radio option? Thanks in advance!
67 C10 Fleetside SOLD 67 C10 SWB Fleetside 67 C20 Fleetside 68 C10 Fleetside 68 C20 Fleetside SOLD 72 k20 Pay Pal: Grant.Furneaux@gmail.com |
Re: 67 No factory radio option?
Beautiful c10 right there. The am radio was optional. Check your spid on the glove box door if it's still there
![]() 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
Radio was not standard equipment on any 67-72. Simply, your truck was not ordered with an optional radio.
Steve weim55 Colorado |
Nothing mentioning a radio on the SPID.
I thought it was standard. Would there be a delete in its place of a radio?
Posted via Mobile Device |
Yes, A rectangle plate the same color as the dashboard to cover the radio holes.
![]() Join Date: Feb 2002
Another '67 MY quirk: Don't freak when you turn the light switch on and the Parking Lights go out when the Headlights come up. That's normal for this model year. They will still blink as turn signals.
A lot of Federal safety changes [including side markers] were mandated in 1968. I had to cut a hole in the cowl for the AM/FM antenna on my '67 K/10 Suburban. No factory radio. To not interfere with the CB whip * on the passenger side; I put it on the drivers side. PO had put in an Alpine cassette/receiver deck but had a loose stick antenna on the dash. [* Yes., it was a long time ago.]
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 04-28-2020 at 04:43 PM. |
![]() Join Date: Nov 2012
Radios back then were mostly AM and AM radios do not require the antennas like FM ones do.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
Fantastic truck, congrats!
![]() Join Date: May 2006
interesting, didn't know that
I have owned many AM radios when I was a child, and NONE of them had an exterior antenna. Only the FM ones. I think AM radios use an internal wire for antennas.
![]() Join Date: May 2010
These AM truck radios had horrible reception even with the telescoping antennas extended to their full length. I never saw any radio equipped vehicle without an antenna prior to the change that placed a different type of antenna on/in the windshield glass. Are you sure those you experienced as a kid just had some sort of hidden antenna?
Jim Last edited by FirstOwner69; 04-29-2020 at 12:05 AM. |
All the vehicles with AM radio I have ever seen had an antenna. They used to say FM required a 31" mast. That is the only deference between AM/FM I have ever known. But now that FM became standard I see a variety of lengths. In the '80s I bought a less than 12" flexy rubbery antenna for my work truck with ladder racks. Work perfectly, so not sure what that 31" thing was about. Ideal length but apparently doesn't matter.
#15 |
![]() Join Date: Oct 2017
Very cool truck.
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
#16 |
Special K is correct . I have never seen one that didnt have the antenna and my 67 is a non radio C30 and i have seen few people baffled because the cowl didnt have the hole.lol
#17 |
As far as I knew my AM radios typically did not have any external antenna. But I may be wrong.
My 67 GMC 3500 had a factory AM radio in it, but NO antenna on the cowl or anywhere else. The cowl does not even have a hole for one. Confusing!
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion Last edited by HIGHWAY BY THE SEA; 04-29-2020 at 11:04 PM. |
