04-27-2020, 06:48 PM | #1 |
Leaf spring suspension lowering question
Hi all, I have a 70 GMC long bed with stock suspension and I'd like to put a 5/7 static drop on it. Is it worth it to convert it to coils in the rear or just go with a leaf spring drop in the rear? What are the pros and cons without converting to coils? I have read that the ride can be harsh compared to coils but as of now it has a very nice ride.
04-27-2020, 07:34 PM | #2 |
Re: Leaf spring suspension lowering question
If you are happy with the ride in rear and want a 7" drop just use a flip kit. Ride should not change much if at all. Note that if you do not notch the frame you will be riding on or very close. ie: no suspension travel.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-27-2020, 08:42 PM | #3 |
Hmmm I didn't realize 7" drop in the rear would get so close to the axle. I may have to go 4/6.
04-28-2020, 04:22 PM | #4 |
The ride in my 71 with leafs is really not bad at all. I even have a coil C/20 to compare it to. I would love to drop the leaf 71 but it just seems a lot more work then a coil rear.
71 C-20 07 Magnum RT AWD |
04-28-2020, 07:56 PM | #5 |
That's what I thought too but I spoke to Frank at Franks Pickmups and he's got a very simple drop kit. I believe he is on this forum if you wanted to contact him. I contacted him through craigslist as he is in Olympia south of Seattle, where I am.
